Estimating stop over duration in the presence of trap-effects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ecological Modelling Année : 2013
Detection probability of individuals is increasingly taken into account during field monitoring schemes and in demographic models. Conversely, it is often taken for granted that trappability of animals will remain fairly constant and broadly similar between individuals present in a given area. However, animals may change their behaviour after being trapped. In this paper, we introduce a new hidden Markovian model to estimate stop over duration in the presence of trap-effects. This model combines nonhomogeneous Markovian states with semi-Markovian states in the non-observable state process, and simple distributions with first-order Markov chains as observation models. This model generalizes previously proposed models and enables the joint modeling of the time of residence and the trap effect. Two cases are considered, depending on whether or not emigration is time-dependent since arrival. We illustrate the latter with teal Anas crecca wintering in Camargue, Southern France and we demonstrate the importance of handling trap-effects.
hal-00828839 , version 1 (31-05-2013)
Rémi Choquet, Yann Guédon, Aurélien Besnard, Matthieu Guillemain, Roger Pradel. Estimating stop over duration in the presence of trap-effects. Ecological Modelling, 2013, 250, pp.111-118. ⟨10.1016/j.ecolmodel.2012.11.002⟩. ⟨hal-00828839⟩
208 Consultations
0 Téléchargements
