New interface
Journal articles
Probabilistic approach for predicting periodic orbits in piecewise affine differential models
Madalena Chaves 1 Etienne Farcot 2, 3 Jean-Luc Gouzé 1
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
2 VIRTUAL PLANTS - Modeling plant morphogenesis at different scales, from genes to phenotype
CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique, UMR AGAP - Amélioration génétique et adaptation des plantes méditerranéennes et tropicales
Abstract : Piecewise affine models provide a qualitative description of the dynamics of a system, and are often used to study genetic regulatory networks. The state space of a piecewise affine system is partitioned into hyperrectangles, which can be represented as nodes in a directed graph, so that the system's trajectories follow a path in a transition graph.This paper proposes and compares two definitions of probability of transition between two nodes A and B of the graph, based on the volume of the initial conditions on the hyperrectangle A whose trajectories cross to B. The parameters of the system can thus be compared to the observed transitions between two hyperrectangles. This property may become useful to identify sets of parameters for which the system yields a desired periodic orbit with a high probability, or to predict the most likely periodic orbit given a set of parameters, as illustrated by a gene regulatory system composed of two intertwined negative loops.
Keywords : Genetic networks
Document type :
Journal articles
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-00828847
Contributor : Christophe Godin Connect in order to contact the contributor
Submitted on : Wednesday, January 7, 2015 - 11:01:43 AM
Last modification on : Sunday, May 1, 2022 - 3:14:22 AM
Long-term archiving on: : Friday, September 11, 2015 - 1:05:32 AM
chaves-farcot-gouze-bmb2013.pd...
Identifiers
Citation
Madalena Chaves, Etienne Farcot, Jean-Luc Gouzé. Probabilistic approach for predicting periodic orbits in piecewise affine differential models. Bulletin of Mathematical Biology, 2013, 75 (6), pp.967-987. ⟨10.1007/s11538-012-9773-6⟩. ⟨hal-00828847⟩
Share
Metrics
Record views
170
Files downloads
160
