On measure solutions of the Boltzmann equation, Part II: Rate of convergence to equilibrium
Abstract : The paper considers the convergence to equilibrium for measure solutions of the spatially homogeneous Boltzmann equation for hard potentials with angular cutoff. We prove the exponential sharp rate of strong convergence to equilibrium for conservative measure solutions having finite mass and energy. The proof is based on the regularizing property of the iterated collision operators, exponential moment production estimates, and some previous results on the exponential rate of strong convergence to equilibrium for square integrable initial data. We also obtain a lower bound of the convergence rate and deduce that no eternal solutions exist apart from the trivial stationary solutions given by the Maxwellian equilibrium. We finally use these convergence rates in order to deduce global-in-time strong stability of measure solutions.
Type de document :
Pré-publication, Document de travail
60 pages -- some typos corrected and explanations added in the new version. 2015
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-00829882
Contributeur : Clément Mouhot <>
Soumis le : lundi 26 janvier 2015 - 11:48:02
Dernière modification le : lundi 21 mars 2016 - 11:33:54
Document(s) archivé(s) le : lundi 27 avril 2015 - 10:21:10
Fichiers
LM-partII-v9.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : hal-00829882, version 2
  • ARXIV : 1306.0764
Collections
Citation
Lu Xuguang, Clément Mouhot. On measure solutions of the Boltzmann equation, Part II: Rate of convergence to equilibrium. 60 pages -- some typos corrected and explanations added in the new version. 2015. <hal-00829882v2>
Métriques
Consultations de
la notice
64
Téléchargements du document
41
