Assessment of Digital Image Correlation Measurement Errors: Methodology and Results, Experimental Mechanics, vol.43, issue.4, pp.49353-370, 2009. ,
DOI : 10.1007/s11340-008-9204-7
URL : https://hal.archives-ouvertes.fr/hal-00881043
Assessment of measuring errors in DIC using deformation fields generated by plastic FEA, Optics and Lasers in Engineering, vol.47, issue.7-8, pp.747-753, 2009. ,
DOI : 10.1016/j.optlaseng.2009.03.007
Quantitative Error Assessment in Pattern Matching: Effects of Intensity Pattern Noise, Interpolation, Strain and Image Contrast on Motion Measurements, Strain, vol.47, issue.2, pp.160-178, 2009. ,
DOI : 10.1111/j.1475-1305.2008.00592.x
Application of iteration and finite element smoothing technique for displacement and strain measurement of digital speckle correlation, Optics and Lasers in Engineering, vol.45, issue.1, pp.57-63, 2007. ,
DOI : 10.1016/j.optlaseng.2006.04.012
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, 2012. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
Two-dimensional deconvolution applied to phase-stepped shearography, Optics and Lasers in Engineering, vol.26, issue.4-5, pp.1594-1602, 2006. ,
DOI : 10.1016/0143-8166(95)00138-7
Restoration of blurred images for surface roughness evaluation using machine vision, Tribology International, vol.43, issue.1-2, pp.268-276, 2010. ,
DOI : 10.1016/j.triboint.2009.05.030
Producing and transferring low-spatial-frequency grids for measuring displacement fields with moiré and grid methods, Experimental Techniques, pp.23-26, 2004. ,
Using deconvolution to improve the metrological performance of the grid method, Optics and Lasers in Engineering, vol.51, issue.6, 2013. ,
DOI : 10.1016/j.optlaseng.2013.01.009
