The Complexity of Valued Constraint Satisfaction Problems in a Nutshell
The valued constraint satisfaction problem was introduced by Schiex et al. [23] as a unifying framework for studying constraint programming with soft constraints. A systematic worst-case complexity theoretical investigation of this problem was initiated by Cohen et al. [4], building on ideas from the successful classi cation programme for the ordinary constraint satisfaction problem. In addition to the decision problem for constraint satisfaction, this framework also captures problems as varied as Max CSP and integer programming with bounded domains. This paper is intended to give a quick introduction to the questions, the main results, and the current state of the complexity classi cation of valued constraint satisfaction problems. Two special cases are looked at in some detail : the classi cation for the Boolean domain and the less well-understood case of Max CSP. Some recent results for general constraint languages are also reviewed, as well as the connection to the very active study of approximation algorithms for Max CSP.
Intelligence artificielle [cs.AI]
