Robust satisfiability of constraint satisfaction problems, Proceedings of the 44th symposium on Theory of Computing, STOC '12, 2012. ,
DOI : 10.1145/2213977.2214061
Generalising submodularity and horn clauses: Tractable optimization problems defined by tournament pair multimorphisms, Theoretical Computer Science, vol.401, issue.1-3, pp.36-51, 2008. ,
DOI : 10.1016/j.tcs.2008.03.015
Supermodular functions and the complexity of MAX CSP, Discrete Applied Mathematics, vol.149, issue.1-3, pp.53-72, 2005. ,
DOI : 10.1016/j.dam.2005.03.003
The complexity of soft constraint satisfaction, Artificial Intelligence, vol.170, issue.11, pp.983-1016, 2006. ,
DOI : 10.1016/j.artint.2006.04.002
An Algebraic Theory of Complexity for Valued Constraints: Establishing a Galois Connection, Proceedings of MFCS-2011, pp.231-242, 2011. ,
DOI : 10.1007/978-3-642-22993-0_23
Cooper and Stanislav?ivn´yStanislav?Stanislav?ivn´Stanislav?ivn´y Tractable triangles, Proceedings of CP-2011, pp.195-209, 2011. ,
A Dichotomy Theorem for Maximum Generalized Satisfiability Problems, Journal of Computer and System Sciences, vol.51, issue.3, pp.511-522, 1995. ,
DOI : 10.1006/jcss.1995.1087
Complexity classifications of boolean constraint satisfaction problems, SIAM, 2001. ,
DOI : 10.1137/1.9780898718546
The approximability of MAX CSP with fixed-value constraints, Journal of the ACM, vol.55, issue.4, pp.1-37, 2008. ,
DOI : 10.1145/1391289.1391290
Improved approximation algorithms for maximum cut and satisfiability problems using semidefinite programming, J. ACM, vol.42, pp.1115-1145, 1995. ,
The Approximability of Three-valued MAX CSP, SIAM Journal on Computing, vol.35, issue.6, pp.1329-1349, 2006. ,
DOI : 10.1137/S009753970444644X
MAX ONES Generalized to Larger Domains, SIAM Journal on Computing, vol.38, issue.1, pp.329-365, 2008. ,
DOI : 10.1137/060669231
Min CSP on Four Elements: Moving beyond Submodularity, Proceedings of CP- 2011, pp.438-453, 2011. ,
DOI : 10.1007/978-3-642-23786-7_34
Introduction to the Maximum Solution Problem, Complexity of Constraints ? An Overview of Current Research, pp.255-282, 2008. ,
DOI : 10.1137/0403037
Approximability of the Maximum Solution Problem for Certain Families of Algebras, Proceedings of CSR-2009, pp.215-226, 2009. ,
DOI : 10.1017/S1446788700029979
The Approximability of Constraint Satisfaction Problems, SIAM Journal on Computing, vol.30, issue.6, pp.1863-1920, 2000. ,
DOI : 10.1137/S0097539799349948
On the Unique Games Conjecture (Invited Survey), 2010 IEEE 25th Annual Conference on Computational Complexity, pp.99-121, 2010. ,
DOI : 10.1109/CCC.2010.19
The complexity of conservative valued CSPs, Proceedings of SODA-2012, pp.750-759, 2012. ,
DOI : 10.1145/2450142.2450146
Linear programming, width-1 CSPs, and robust satisfaction, Proceedings of the 3rd Innovations in Theoretical Computer Science Conference on, ITCS '12, pp.484-495, 2012. ,
DOI : 10.1145/2090236.2090274
Optimal algorithms and inapproximability results for every CSP?, Proceedings of the fourtieth annual ACM symposium on Theory of computing, STOC 08, pp.245-254, 2008. ,
DOI : 10.1145/1374376.1374414
How to Round Any CSP, 2009 50th Annual IEEE Symposium on Foundations of Computer Science, pp.586-594, 2009. ,
DOI : 10.1109/FOCS.2009.74
The complexity of satisfiability problems, Proceedings of the tenth annual ACM symposium on Theory of computing , STOC '78, pp.216-226, 1978. ,
DOI : 10.1145/800133.804350
Valued constraint satisfaction problems : Easy and hard problems, Proceedings of IJCAI-1995, pp.631-637, 1995. ,
The Power of Linear Programming for Valued CSPs, 2012 IEEE 53rd Annual Symposium on Foundations of Computer Science, p.2012 ,
DOI : 10.1109/FOCS.2012.25
