Preprints, Working Papers, ...
Nonparametric estimation of extreme risks from conditional heavy-tailed distributions
Jonathan El Methni 1 Laurent Gardes 2 Stéphane Girard 1
1 MISTIS - Modelling and Inference of Complex and Structured Stochastic Systems
Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, LJK - Laboratoire Jean Kuntzmann, Inria Grenoble - Rhône-Alpes
Abstract : In this paper, we introduce a new risk measure, the so-called Conditional Tail Moment. It is the moment of order a>0 of the loss distribution above the upper alpha-quantile. Estimating the Conditional Tail Moment permits to estimate all risk measures based on conditional moments such as Value-at-Risk, Conditional Tail Expectation, Conditional Value-at-Risk or Conditional Tail Variance. Here, we focus on the estimation of these risk measures in case of extreme losses (where alpha converges to 0). It is moreover assumed that the loss distribution is heavy-tailed and depends on a covariate. The estimation method thus combines nonparametric kernel methods with extreme-value statistics. The asymptotic distribution of the estimators is established and their finite sample behavior is illustrated both on simulated data and on a real data set of daily rainfalls in the Cévennes-Vivarais region (France).
Document type :
Complete list of metadatas
https://hal.archives-ouvertes.fr/hal-00830647
Contributor : Stephane Girard <>
Submitted on : Monday, June 10, 2013 - 10:03:02 AM
Last modification on : Tuesday, February 9, 2021 - 3:20:19 PM
Long-term archiving on: : Tuesday, April 4, 2017 - 6:52:11 PM
File
CTM2.pdf
Identifiers
  • HAL Id : hal-00830647, version 2
Citation
Jonathan El Methni, Laurent Gardes, Stéphane Girard. Nonparametric estimation of extreme risks from conditional heavy-tailed distributions. 2013. ⟨hal-00830647v2⟩
Share
Metrics
Record views
111
Files downloads
57
