Singular solutions in optimal control: second order conditions and a shooting algorithm, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00631564
Quadratic order conditions for bang-singular extremals . Numerical Algebra, Control and Optimization, AIMS Journal, vol.2, issue.3, pp.511-546, 2012. ,
A wellposed shooting algorithm for optimal control problems with singular arcs, J. Optim. Theory Appl, 2013. ,
Optimal control and viscosity solutions of Hamilton-Jacobi-Bellman equations . Systems and Control: Foundations and Applications, 1997. ,
Optimal control of a semilinear parabolic equation with singular arcs, Optimization Methods and Software, vol.37, issue.2, 2012. ,
DOI : 10.1007/s10107-004-0559-y
URL : https://hal.archives-ouvertes.fr/hal-00740698
Well-Posedness of the Shooting Algorithm for State Constrained Optimal Control Problems with a Single Constraint and Control, SIAM Journal on Control and Optimization, vol.46, issue.4, pp.1398-1430, 2007. ,
DOI : 10.1137/06065756X
URL : https://hal.archives-ouvertes.fr/inria-00071379
Stability and sensitivity analysis for optimal control problems with a first-order state constraint and application to continuation methods, ESAIM: Control, Optimisation and Calculus of Variations, vol.14, issue.4, pp.825-863, 2008. ,
DOI : 10.1051/cocv:2008016
Second-order analysis for optimal control problems with pure state constraints and mixed control-state constraints, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.2, pp.561-598, 2009. ,
DOI : 10.1016/j.anihpc.2007.12.002
URL : https://hal.archives-ouvertes.fr/hal-00778357
Optimal Control of a Parabolic Equation with Time-Dependent State Constraints, SIAM Journal on Control and Optimization, vol.48, issue.7, pp.4550-4571, 2010. ,
DOI : 10.1137/080744608
URL : https://hal.archives-ouvertes.fr/inria-00348854
Computation of order conditions for symplectic partitioned Runge-Kutta schemes with application to optimal control, Numerische Mathematik, vol.103, issue.1, pp.1-10, 2006. ,
DOI : 10.1007/s00211-005-0661-y
URL : https://hal.archives-ouvertes.fr/inria-00070605
Perturbation analysis of optimization problems, 2000. ,
DOI : 10.1007/978-1-4612-1394-9
Singular Arcs in the Generalized Goddard???s Problem, Journal of Optimization Theory and Applications, vol.106, issue.2, pp.439-461, 2008. ,
DOI : 10.1007/s10957-008-9387-1
Bocop v1.0.3: A collection of examples, 2012. ,
First- and Second-Order Optimality Conditions for Optimal Control Problems of State Constrained Integral Equations, Journal of Optimization Theory and Applications, vol.1, issue.2 ,
DOI : 10.1007/s10957-013-0299-3
URL : https://hal.archives-ouvertes.fr/hal-00697504
OPTIMAL PROGRAMMING PROBLEMS WITH INEQUALITY CONSTRAINTS, AIAA Journal, vol.1, issue.11 ,
DOI : 10.2514/3.2107
Méthode générale pour la résolution des systèmes d'´ equations simultanées, Comptes Rendus de l'Académie des Sciences de Paris, pp.536-538, 1847. ,
Quadratic conditions for the Pontryagin minimum in an optimal control problem linear with respect to control. II. Theorems on the relaxing of constraints on the equality, Izv. Akad. Nauk SSSR Ser. Mat, vol.51, issue.4, pp.812-832, 1987. ,
Necessary Conditions for Singular Extremals Involving Multiple Control Variables, SIAM Journal on Control, vol.4, issue.4, pp.716-731, 1966. ,
DOI : 10.1137/0304052
The Numerical Integration of Two-Point Boundary Value Problems, Mathematical Tables and Other Aids to Computation, vol.10, issue.54, pp.82-86, 1956. ,
DOI : 10.2307/2002181
Runge-Kutta methods in optimal control and the transformed adjoint system, Numerische Mathematik, vol.87, issue.2, pp.247-282, 2000. ,
DOI : 10.1007/s002110000178
Homotopy Algorithm for Optimal Control Problems with a Second-order State Constraint, Applied Mathematics and Optimization, vol.5, issue.2, pp.85-127, 2010. ,
DOI : 10.1007/s00245-009-9076-y
URL : https://hal.archives-ouvertes.fr/inria-00316281
Optimal control of the atmospheric reentry of a space shuttle by an homotopy method, Optimal Control Applications and Methods, vol.8, issue.1, pp.627-646, 2011. ,
DOI : 10.1002/oca.961
URL : https://hal.archives-ouvertes.fr/inria-00317722
New necessary conditions of optimality for control problems with state-variable inequality constraints, Journal of Mathematical Analysis and Applications, vol.35, issue.2, pp.255-284, 1971. ,
DOI : 10.1016/0022-247X(71)90219-8
Solution point differentiability without strict complementarity in nonlinear programming, Mathematical Programming, pp.127-138, 1984. ,
DOI : 10.1007/BFb0121215
Optimal control of systems governed by partial differential equations. Translated from the French by S. K. Mitter. Die Grundlehren der mathematischen Wissenschaften, Band, vol.170, 1971. ,
Non-homogeneous boundary value problems and applications, 1972. ,
DOI : 10.1007/978-3-642-65161-8
Differential stability of solutions to convex, control constrained optimal control problems, Applied Mathematics & Optimization, vol.5, issue.1, pp.1-14, 1984. ,
DOI : 10.1007/BF01449030
Sensitivity analysis for state constrained optimal control problems, Discrete Contin. Dynam. Systems, vol.4, issue.2, pp.241-272, 1998. ,
Convergence of approximations to nonlinear optimal control problems, Mathematical programming with data perturbations, pp.253-284, 1998. ,
Numerical Study of Optimal Trajectories with Singular Arcs for an Ariane 5 Launcher, Journal of Guidance, Control, and Dynamics, vol.32, issue.1, pp.51-55, 2009. ,
DOI : 10.2514/1.37387
URL : https://hal.archives-ouvertes.fr/hal-00312012
On Optimal Control Problems with Bounded State Variables and Control Appearing Linearly, SIAM Journal on Control and Optimization, vol.15, issue.3, pp.345-362, 1977. ,
DOI : 10.1137/0315023
On the minimum principle for optimal control problems with state constraints, 1979. ,
Solution Differentiability for Nonlinear Parametric Control Problems, SIAM Journal on Control and Optimization, vol.32, issue.6, pp.1542-1554, 1994. ,
DOI : 10.1137/S0363012992232269
Solution differentiability for parametric nonlinear control problems with control-state constraints, Journal of Optimization Theory and Applications, vol.62, issue.2, pp.285-309, 1995. ,
DOI : 10.1007/BF02192081
Osmolovski? ?. Calculus of Variations and Optimal Control, 1998. ,
Multiple shooting method for two-point boundary value problems, Communications of the ACM, vol.5, issue.12, pp.613-614, 1962. ,
DOI : 10.1145/355580.369128
Applications to regular and bang-bang control Second-order necessary and sufficient optimality conditions in calculus of variations and optimal control, Advances in Design and Control. Society for Industrial and Applied Mathematics (SIAM), vol.24 ,
The mathematical theory of optimal processes, 1986. ,
Unique continuation for some evolution equations, Journal of Differential Equations, vol.66, issue.1, pp.118-139, 1987. ,
DOI : 10.1016/0022-0396(87)90043-X
Geometric optimal control, Theory, methods and examples ,
DOI : 10.1007/978-1-4614-3834-2
Introduction to Numerical Analysis, 1993. ,
