Towards a better understanding of pelvic system disorders using numerical simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Genital prolapse is a pathologic hyper-mobility of the organs that forms the pelvic system. Although this is common condition, the pathophysiology of this disorder is not well known. In order to improve the understanding of its origins, we recreate - virtually - this biomechanical pathology using numerical simulation. The approach builds on a finite element model with parameters measured on several fresh cadavers. The meshes are created from a MRI of a healthy woman and the simulation includes the mechanical interactions between organs (contacts, ligaments, adhesion...). The model is validated through comparison of functional mobilities of the pelvic system observed on a dynamic MRI. We then propose to modify, step by step, the model and its parameters to produce a pathologic situation and have a better understanding of the process. It is not a formal proof but the numerical experiments reinforce the clinical hypothesis on the multifactorial origins of the pathology.
paper_819.pdf (5.71 Mo) Télécharger le fichier
file819-1.mp4 (7.23 Mo) Télécharger le fichier
Format : Autre
hal-00831245 , version 1 (06-12-2013)
  • HAL Id : hal-00831245 , version 1
Pauline Lecomte-Grosbras, Mouhamadou Nassirou - Diallo, Jean-François Witz, Damien Marchal, Jérémie Dequidt, et al.. Towards a better understanding of pelvic system disorders using numerical simulation. Medical Image Computing and Computer Assisted Intervention, Sep 2013, Nagoya, Japan. ⟨hal-00831245⟩
563 Consultations
313 Téléchargements
