Trajectory planning/re-planning for satellite systems in rendezvous mission in the presence of actuator faults based on attainable efforts analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Systems Science Année : 2015
The objective of Fault-tolerant Control (FTC) is to minimize the effect of faults on systems performance (stability, trajectory tracking, etc.). However, the majority of the existing FTC methods continue to force the system to follow the pre-fault trajectories without considering the reduction in available control resources caused by actuator faults. Forcing the system to follow the same trajectories as before fault occurrence may result in actuator saturation and system's instability. Thus, pre-fault objectives should be redefined in function of the remaining resources to avoid potential saturation. The main contribution of this paper is a flatness-based trajectory planning/re-planning method that can be combined with any active FTC approach. The work considers the case of over-actuated systems where a new idea is proposed to evaluate the severity of faults occurred. In addition, the trajectory planning/re-planning approach is formulated as an optimization problem based on the analysis of attainable efforts domain in fault-free and fault cases. The proposed approach is applied to two satellite systems in \textit{rendezvous} mission
Paper_WWW.pdf (788.56 Ko) Télécharger le fichier
hal-00831637 , version 1 (07-06-2013)
Abbas Chamseddine, Cédric Join, Didier Theilliol. Trajectory planning/re-planning for satellite systems in rendezvous mission in the presence of actuator faults based on attainable efforts analysis. International Journal of Systems Science, 2015, 46 (4), pp.690-701. ⟨10.1080/00207721.2013.797034⟩. ⟨hal-00831637⟩
135 Consultations
303 Téléchargements
