An exponential integrator for a highly oscillatory Vlasov equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Continuous Dynamical Systems - Series S Année : 2015
In the framework of a Particle-In-Cell scheme for some 1D Vlasov-Poisson system depending on a small parameter, we propose a time-stepping method which is numerically uniformly accurate when the parameter goes to zero. Based on an exponential time differencing approach, the scheme is able to use large time steps with respect to the typical size of the fast oscillations of the solution.
paper_etd.pdf (522.47 Ko) Télécharger le fichier
hal-00833479 , version 1 (13-06-2013)
Emmanuel Frenod, Sever Adrian Hirstoaga, Eric Sonnendrücker. An exponential integrator for a highly oscillatory Vlasov equation. Discrete and Continuous Dynamical Systems - Series S, 2015, 8 (1), pp.169-183. ⟨10.3934/dcdss.2015.8.169⟩. ⟨hal-00833479⟩
410 Consultations
317 Téléchargements
