A cooperative search method for the $k$-coloring problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Mathematical Modelling and Algorithms Année : 2008
In this paper, a cooperative search method, based on a multi-agent structure is developed to deal with the $k$-coloring problem. Three agents coordinate using an adaptive memory, a search agent, an intensification agent and a diversification agent. We use the results of a preliminary fitness landscape study to adjust the navigation strategy in the solution space and to fix the search parameters. Our method provides competitive results and it is fast when compared with best existing techniques on instances extracted from the second DIMACS challenge.
hal-00836812 , version 1 (21-06-2013)
Hind Bouziri, El-Ghazali Talbi, Khaled Mellouli. A cooperative search method for the $k$-coloring problem. Journal of Mathematical Modelling and Algorithms, 2008, 7 (2), pp.125-142. ⟨10.1007/s10852-008-9081-1⟩. ⟨hal-00836812⟩
55 Consultations
0 Téléchargements
