Improving pairwise coreference models through feature space hierarchy learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper proposes a new method for significantly improving the performance of pairwise coreference models. Given a set of indicators, our method learns how to best separate types of mention pairs into equivalence classes for which we construct distinct classification models. In effect, our approach finds an optimal feature space (derived from a base feature set and indicator set) for discriminating coreferential mention pairs. Although our approach explores a very large space of possible feature spaces, it remains tractable by exploiting the structure of the hierarchies built from the indicators. Our experiments on the CoNLL-2012 Shared Task English datasets (gold mentions) indicate that our method is robust relative to different clustering strategies and evaluation metrics, showing large and consistent improvements over a single pairwise model using the same base features. Our best system obtains a competitive 67:2 of average F1 over MUC, B3 , and CEAF which, despite its simplicity, places it above the mean score of other systems on these datasets.
main.pdf (166.64 Ko) Télécharger le fichier
hal-00838192 , version 1 (25-06-2013)
  • HAL Id : hal-00838192 , version 1
Emmanuel Lassalle, Pascal Denis. Improving pairwise coreference models through feature space hierarchy learning. ACL 2013 - Annual meeting of the Association for Computational Linguistics, Association for Computational Linguistics, Aug 2013, Sofia, Bulgaria. ⟨hal-00838192⟩
333 Consultations
100 Téléchargements
