Asymptotics of several-partition Hurwitz numbers
We derive in this paper the asymptotics of several-partition Hurwitz numbers, relying on a theorem of Kazarian for the one-partition case and on an induction carried on by Zvonkine. Essentially, the asymptotics for several partitions is the same as the one-partition asymptotics obtained by concatenating the partitions.
Combinatoire [math.CO]
