Counting Points on Curves and Abelian Varieties Over Finite Fields, Journal of Symbolic Computation, vol.32, issue.3, pp.171-189, 2001. ,
DOI : 10.1006/jsco.2001.0470
URL : http://doi.org/10.1006/jsco.2001.0470
A subexponential algorithm for discrete logarithms over the rational subgroup of the Jacobians of large genus hyperelliptic curves over finite fields, ANTS-I, pp.28-40, 1994. ,
DOI : 10.1007/3-540-58691-1_39
Point counting on Picard curves in large characteristic, Mathematics of Computation, vol.74, issue.252, pp.1983-2005, 2005. ,
DOI : 10.1090/S0025-5718-05-01758-8
Handbook of Magma functions, 1997. ,
Moyenne arithmético-géométrique et périodes de courbes de genre 1 et 2, pp.36-64, 1988. ,
Linear Recurrences with Polynomial Coefficients and Computation of the Cartier-Manin Operator on Hyperelliptic Curves, Finite Fields and Applications, 7th International Conference, Fq7, pp.40-58, 2004. ,
DOI : 10.1007/978-3-540-24633-6_4
URL : https://hal.archives-ouvertes.fr/inria-00514132
Linear Recurrences with Polynomial Coefficients and Application to Integer Factorization and Cartier???Manin Operator, SIAM Journal on Computing, vol.36, issue.6, pp.1777-1806, 2007. ,
DOI : 10.1137/S0097539704443793
URL : https://hal.archives-ouvertes.fr/inria-00103401
On the analogue of the division polynomials for hyperelliptic curves, J. Reine Angew. Math, vol.447, pp.91-145, 1994. ,
A p-Adic Quasi-Quadratic Time Point Counting Algorithm, International Mathematics Research Notices, pp.698-735, 2009. ,
DOI : 10.1093/imrn/rnn143
URL : https://hal.archives-ouvertes.fr/hal-00383103
Computing zeta functions of nondegenerate curves, International Mathematics Research Papers, 2006. ,
DOI : 10.1155/IMRP/2006/72017
Computing Zeta Functions in Families of C a,b Curves Using Deformation, ANTS-VIII, pp.296-311, 2008. ,
DOI : 10.1007/978-3-540-79456-1_20
Compter (rapidement) le nombre de solutions d'´ equations dans les corps finis, Séminaire Bourbaki, p.968, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00133408
Enumeration of rational points on elliptic curves over finite fields. Draft, 1991. ,
Computing l-isogenies using the p-torsion, Second International Symposium, ANTS-II, pp.59-65, 1996. ,
DOI : 10.1007/3-540-61581-4_41
Algebraic groups and discrete logarithm, Public-key cryptography and computational number theory, pp.17-27, 2001. ,
DOI : 10.1515/9783110881035.17
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.5372
Counting points on C ab curves using Monsky-Washnitzer cohomology. Finite Fields and Their Applications, pp.78-102, 2006. ,
An Extension of Kedlaya's Algorithm to Hyperelliptic Curves in Characteristic 2, Journal of Cryptology, vol.19, issue.1, pp.1-25, 2006. ,
DOI : 10.1007/s00145-004-0231-y
Moyenne arithmético-géométrique, suites de Borchardt et applications, 2006. ,
Computing discrete logarithms in high-genus hyperelliptic Jacobians in provably subexponential time, Mathematics of Computation, vol.71, issue.238, pp.729-742, 2002. ,
DOI : 10.1090/S0025-5718-01-01363-1
A general framework for subexponential discrete logarithm algorithms, Acta Arithmetica, vol.102, issue.1, pp.83-103, 2002. ,
DOI : 10.4064/aa102-1-6
URL : https://hal.archives-ouvertes.fr/inria-00512717
SEA in genus 1: 2500 decimal digits, 2006. ,
An extension of Satoh's algorithm and its implementation, J. Ramanujan Math. Soc, vol.15, pp.281-318, 2000. ,
NTLJac2, Tools for genus 2 Jacobians in NTL ,
A Comparison and a Combination of SST and AGM Algorithms for Counting Points of Elliptic Curves in Characteristic 2, Advances in Cryptology ? ASIACRYPT 2002, pp.311-327, 2002. ,
DOI : 10.1007/3-540-36178-2_20
URL : https://hal.archives-ouvertes.fr/inria-00514137
Counting Points in Medium Characteristic Using Kedlaya's Algorithm, Experimental Mathematics, vol.23, issue.1, pp.395-402, 2003. ,
DOI : 10.1080/10586458.2003.10504508
Construction of Secure Random Curves of Genus 2 over Prime Fields, Advances in Cryptology ? EUROCRYPT 2004, pp.239-256, 2004. ,
DOI : 10.1007/978-3-540-24676-3_15
URL : https://hal.archives-ouvertes.fr/inria-00514121
Modular equations for hyperelliptic curves, Mathematics of Computation, vol.74, issue.249, pp.429-454, 2005. ,
DOI : 10.1090/S0025-5718-04-01682-5
URL : https://hal.archives-ouvertes.fr/inria-00000627
Asymptotically optimal p-adic point-counting. e-mail to the NMBRTHRY list, 2002. ,
Cardinality of a genus 2 hyperelliptic curve over GF (2 4001 ). e-mail to the NMBRTHRY list, 2002. ,
Kedlaya's Algorithm in Larger Characteristic, International Mathematics Research Notices, 2007. ,
DOI : 10.1093/imrn/rnm095
URL : http://arxiv.org/abs/math/0610973
Computing relations in divisor class groups of algebraic curves over finite fields, 2004. ,
Counting Points on Curves over Finite Fields, Journal of Symbolic Computation, vol.25, issue.1, pp.1-21, 1998. ,
DOI : 10.1006/jsco.1997.0164
Abstract, LMS Journal of Computation and Mathematics, vol.7, pp.207-234, 2007. ,
Point Counting in Families of Hyperelliptic Curves, Foundations of Computational Mathematics, vol.7, issue.1, pp.137-169, 2008. ,
DOI : 10.1007/s10208-007-9000-2
Quasi-quadratic elliptic curve point counting using rigid cohomology, Journal of Symbolic Computation, vol.44, issue.9, pp.1255-1267, 2009. ,
DOI : 10.1016/j.jsc.2008.02.015
URL : http://doi.org/10.1016/j.jsc.2008.02.015
Counting points on hyperelliptic curves using Monsky-Washnitzer cohomology, J. Ramanujan Math. Soc, vol.16, issue.4, pp.323-338, 2001. ,
Fast Elliptic Curve Point Counting Using Gaussian Normal Basis, Lecture Notes in Comput. Sci, vol.2369, pp.292-307, 2002. ,
DOI : 10.1007/3-540-45455-1_24
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.3.8915
Computing Zeta Functions of Kummer Curves via Multiplicative Characters, Foundations of Computational Mathematics, vol.3, issue.3, pp.273-295, 2003. ,
DOI : 10.1007/s10208-002-0066-6
Deformation theory and the computation of zeta functions, Proc. London Math. Soc, pp.565-602, 2004. ,
DOI : 10.1112/S0024611503014461
Counting points on varieties over finite fields of small characteristic, 2001. ,
Abstract, LMS Journal of Computation and Mathematics, vol.1122, pp.34-55, 2002. ,
DOI : 10.2307/2374675
Computing zeta functions of Artin-Schreier curves over finite fields II, Journal of Complexity, vol.20, issue.2-3, pp.331-349, 2004. ,
DOI : 10.1016/j.jco.2003.08.009
Computing isogenies in $$\mathbb{F}_{2^n } $$, Lecture Notes in Comput. Sci, vol.1122, pp.197-212, 1996. ,
DOI : 10.1007/3-540-61581-4_55
A quasi quadratic time algorithm for hyperelliptic curve point counting, The Ramanujan Journal, vol.2, issue.1, pp.399-423, 2006. ,
DOI : 10.1007/s11139-006-0151-6
URL : https://hal.archives-ouvertes.fr/hal-00456401
Computing isogenies between elliptic curves over $F_{p^n}$ using Couveignes's algorithm, Mathematics of Computation, vol.69, issue.229, pp.351-370, 2000. ,
DOI : 10.1090/S0025-5718-99-01081-9
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.36.4076
Elliptic curves and formal groups In Lecture notes prepared in connection with the seminars held at the Summer Institute on Algebraic Geometry, 1964. ,
A p-adic point counting algorithm for elliptic curves on Legendre form. Finite Fields and Their Applications, pp.71-88, 2005. ,
Algorithmes pour compter des points de courbes en petite caractéristique et en petit genre. Exposé donnédonnéà Rennes en mars, 2002. ,
Utilisation de l'AGM pour le calcul de E(F2n ) Lettre adresséè a Gaudry et Harley, 2000. ,
Computing discrete logarithms in real quadratic congruence function
fields of large genus, Mathematics of Computation, vol.68, issue.226, pp.807-822, 1999. ,
DOI : 10.1090/S0025-5718-99-01040-6
Lifting algebraic curves, abelian varieties, and their endomorphisms to characteristic zero, Algebraic geometry, pp.165-195, 1985. ,
DOI : 10.1090/pspum/046.2/927980
Frobenius maps of abelian varieties and finding roots of unity in finite fields, Mathematics of Computation, vol.55, issue.192, pp.745-763, 1990. ,
DOI : 10.1090/S0025-5718-1990-1035941-X
Essai sur une méthode générale pour déterminer les valeurs des intégrales ultra-elliptiques, fondée sur des transformations remarquables de ces transcendantes, C. R. Acad. Sci. Paris, vol.2, pp.622-627, 1836. ,
Point Counting on Genus 3 Non Hyperelliptic Curves, Lecture Notes in Comput. Sci, vol.3076, pp.379-394, 2004. ,
DOI : 10.1007/978-3-540-24847-7_29
URL : https://hal.archives-ouvertes.fr/hal-01099875
The canonical lift of an ordinary elliptic curve over a finite field and its point counting, J. Ramanujan Math. Soc, vol.15, pp.247-270, 2000. ,
Fast computation of canonical lifts of elliptic curves and its application to point counting. Finite Fields and Their Applications, pp.89-101, 2003. ,
Elliptic curves over finite fields and the computation of square roots mod p, Math. Comp, vol.44, pp.483-494, 1985. ,
Counting points on elliptic curves over finite fields, Journal de Th??orie des Nombres de Bordeaux, vol.7, issue.1, pp.219-254, 1995. ,
DOI : 10.5802/jtnb.142
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.56.4044
NTL: A library for doing number theory ,
Satoh's algorithm in characteristic 2, Mathematics of Computation, vol.72, issue.241, pp.477-487, 2003. ,
DOI : 10.1090/S0025-5718-02-01434-5
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.154.103
Algebraic function fields and codes, 1993. ,
Computing zeta functions of curves over finite fields, 2003. ,
A Memory Efficient Version of Satoh???s Algorithm, Advances in Cryptology ? EUROCRYPT 2001, pp.1-13, 2001. ,
DOI : 10.1007/3-540-44987-6_1
Modern computer algebra, 1999. ,
DOI : 10.1017/CBO9781139856065
A Low-Memory Algorithm for Point Counting on Picard Curves, Designs, Codes and Cryptography, vol.12, issue.143, pp.383-393, 2006. ,
DOI : 10.1007/s10623-005-1598-y
