On the Convergence of Moments in the Central Limit Theorem, The Annals of Mathematical Statistics, vol.36, issue.3, pp.808-818, 1965. ,
DOI : 10.1214/aoms/1177700055
On a new multivariate two-sample test, Journal of Multivariate Analysis, vol.88, issue.1, pp.190-206, 2004. ,
DOI : 10.1016/S0047-259X(03)00079-4
The accuracy of the gaussian approximation to the sum of independent variates. Transactions of the, pp.122-136, 1941. ,
An Introduction to the Bootstrap, 1993. ,
DOI : 10.1007/978-1-4899-4541-9
Kernels based tests with nonasymptotic bootstrap approaches for two-sample problems, COLT, 2012. ,
A fast, consistent kernel twosample test, Advances in Neural Information Processing Systems 22, pp.673-681, 2009. ,
A kernel statistical test of independence, Advances in Neural Information Processing Systems, pp.585-592, 2008. ,
Optimal kernel choice for large-scale two-sample tests, Advances in Neural Information Processing Systems 25, pp.1214-1222, 2012. ,
A kernel two-sample test, J. Mach. Learn. Res, vol.13, pp.723-773, 2012. ,
A kernel method for the two-sample-problem, NIPS, pp.513-520, 2006. ,
Testing for homogeneity with kernel Fisher discriminant analysis, NIPS, pp.609-616, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00270806
Two-stage U-statistics for Hypothesis Testing, Scandinavian Journal of Statistics, vol.4, issue.4, pp.861-873, 2006. ,
DOI : 10.2307/2333467
Continuous univariate distributions. Distributions in statistics, 1994. ,
A scalable bootstrap for massive data, Journal of the Royal Statistical Society: Series B (Statistical Methodology), vol.90, issue.4 ,
DOI : 10.1111/rssb.12050
Sulla determinazione empirica di una legge di distribuzione, Giornale dellIstituto Italiano degli Attuari, pp.83-91, 1933. ,
Support vector learning, 1997. ,
Hypothesis testing using pairwise distances and associated kernels, ICML, 2012. ,
Approximation Theorems of Mathematical Statistics, 1980. ,
Table for Estimating the Goodness of Fit of Empirical Distributions, The Annals of Mathematical Statistics, vol.19, issue.2, pp.279-281, 1948. ,
DOI : 10.1214/aoms/1177730256
Hilbert space embeddings and metrics on probability measures, Journal of Machine Learning Research, vol.11, pp.1517-1561, 2010. ,
Testing for equal distributions in high dimension, InterStat, issue.5, 2004. ,
Measuring and testing dependence by correlation of distances, The Annals of Statistics, vol.35, issue.6, pp.2769-2794, 2007. ,
DOI : 10.1214/009053607000000505
Relative Density-Ratio Estimation for Robust Distribution Comparison, Neural Computation, vol.8, issue.5, pp.1324-1370, 2013. ,
DOI : 10.1137/1.9781611970128
