SAGA " , FP7 contract PITN-GA-2008-214584. E. Tsigaridas is partially supported by the EX- ACTA grant of the National Science Foundation of China (NSFC 60911130369) and the French National Research Agency (ANR-09-BLAN-0371-01 HPAC (ANR ANR-11-BS02-013) and an FP7 Marie Curie Career Integration Grant, GeoLMI (ANR 2011 BS03 011 06) Most of the work of G. Tzoumas was performed during his postdoc at INRIA Nancy and a smaller part during his PhD at the National and Kapodistrian University of Athens ,
Medial axis computation for planar free???form shapes, Computer-Aided Design, vol.41, issue.5, pp.339-349, 2009. ,
DOI : 10.1016/j.cad.2008.08.008
The Voronoi Diagram of Curved Objects, Discrete & Computational Geometry, vol.34, issue.3, pp.439-453, 2005. ,
DOI : 10.1007/s00454-005-1192-0
Voronoi diagrams of semi-algebraic sets, 2004. ,
URL : https://hal.archives-ouvertes.fr/tel-00005932
Computational Geometry Algorithms Library ,
Using Algebraic Geometry. Number 185 in GTM, 2005. ,
Bisector curves of planar rational curves, Computer-Aided Design, vol.30, issue.14, pp.1089-1096, 1998. ,
DOI : 10.1016/S0010-4485(98)00065-7
The Convex Hull of Rational Plane Curves, Graphical Models, vol.63, issue.3, pp.151-162, 2001. ,
DOI : 10.1006/gmod.2001.0546
Exact Delaunay graph of smooth convex pseudo-circles, 2009 SIAM/ACM Joint Conference on Geometric and Physical Modeling on, SPM '09, pp.211-222, 2009. ,
DOI : 10.1145/1629255.1629282
The predicates of the Apollonius diagram: Algorithmic analysis and implementation, Computational Geometry, vol.33, issue.1-2, pp.18-57, 2006. ,
DOI : 10.1016/j.comgeo.2004.02.006
THE PREDICATES FOR THE EXACT VORONOI DIAGRAM OF ELLIPSES UNDER THE EUCLIDIEAN METRIC, International Journal of Computational Geometry & Applications, vol.18, issue.06, pp.567-597, 2008. ,
DOI : 10.1142/S0218195908002763
Exact and efficient evaluation of the InCircle predicate for parametric ellipses and smooth convex objects, Computer-Aided Design, vol.40, issue.6, pp.691-700, 2008. ,
DOI : 10.1016/j.cad.2008.05.001
Computing bitangents for ellipses, Proc. 17th Canad. Conf. Comp. Geom, pp.294-297, 2005. ,
Precise Voronoi cell extraction of free-form rational planar closed curves, Proceedings of the 2005 ACM symposium on Solid and physical modeling , SPM '05, pp.51-59, 2005. ,
DOI : 10.1145/1060244.1060251
VRONI: An engineering approach to the reliable and efficient computation of Voronoi diagrams of points and line segments, Computational Geometry, vol.18, issue.2, pp.95-123, 2001. ,
DOI : 10.1016/S0925-7721(01)00003-7
Topology-oriented incremental computation of Voronoi diagrams of circular arcs and straight-line segments, Computer-Aided Design, vol.41, issue.5, pp.327-338, 2009. ,
DOI : 10.1016/j.cad.2008.08.004
A robust and efficient implementation for the segment Voronoi diagram, Proc. Int. Symp. Voronoi Diagrams, pp.51-62, 2004. ,
The Voronoi Diagram of Convex Objects in the Plane, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00071561
Voronoi diagram of convex objects in the plane, Proc. Europ. Symp. Algorithms, pp.337-348, 2003. ,
Voronoi diagram of a circle set from Voronoi diagram of a point set: II. Geometry, Computer Aided Geometric Design, vol.18, issue.6, pp.563-585, 2001. ,
DOI : 10.1016/S0167-8396(01)00051-6
Randomized incremental construction of abstract Voronoi diagrams, Computational Geometry, vol.3, issue.3, pp.157-184, 1993. ,
DOI : 10.1016/0925-7721(93)90033-3
URL : http://doi.org/10.1016/0925-7721(93)90033-3
Data structures and algorithms for contact detection in numerical simulation of discrete particle systems, World Congress Particle Technology, vol.6, 2010. ,
Voronoi diagram and medial axis algorithm for planar domains with curved boundaries ??? II: Detailed algorithm description, Journal of Computational and Applied Mathematics, vol.102, issue.2, pp.253-277, 1999. ,
DOI : 10.1016/S0377-0427(98)00223-4
URL : http://doi.org/10.1016/s0377-0427(98)00223-4
Voronoi diagram and medial axis algorithm for planar domains with curved boundaries I. Theoretical foundations, Journal of Computational and Applied Mathematics, vol.102, issue.1, pp.119-141, 1999. ,
DOI : 10.1016/S0377-0427(98)00211-8
Constructing medial axis transform of planar domains with curved boundaries, Computer-Aided Design, vol.35, issue.7, pp.619-632, 2003. ,
DOI : 10.1016/S0010-4485(02)00085-4
Voronoi diagram computations for planar NURBS curves, Proceedings of the 2008 ACM symposium on Solid and physical modeling , SPM '08, pp.67-77, 2008. ,
DOI : 10.1145/1364901.1364913
Computational geometry for curved objects. Voronoi diagrams in the plane, 2009. ,
Exact medial axis of quadratic NURBS curves, 27th Proc. Europ. Workshop Computat. Geometry, pp.91-94, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00581588
