New interface
Conference papers
Graded-Inclusion-Based Information Retrieval Systems
Patrick Bosc 1 Vincent Claveau 2 Olivier Pivert 1 Laurent Ughetto 2
1 PILGRIM - Gradedness, Imprecision, and Mediation in Database Management Systems
IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
2 TEXMEX - Multimedia content-based indexing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : This paper investigates the use of fuzzy logic mechanisms coming from the database community, namely graded inclusions, to model the information retrieval process. In this framework, documents and queries are represented by fuzzy sets, which are paired with operations like fuzzy implications and T-norms. Through different experiments, it is shown that only some among the wide range of fuzzy operations are relevant for information retrieval. When appropriate settings are chosen, it is possible to mimic classical systems, thus yielding results rivaling those of state-of-the-art systems. These positive results validate the proposed approach, while negative ones give some insights on the properties needed by such a model. Moreover, this paper shows the added-value of this graded inclusion-based model, which gives new and theoretically grounded ways for a user to easily weight his query terms, to include negative information in his queries, or to expand them with related terms.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-00843880
Contributor : Patrick Gros Connect in order to contact the contributor
Submitted on : Friday, July 12, 2013 - 12:18:45 PM
Last modification on : Thursday, January 20, 2022 - 4:20:19 PM
Links full text
Identifiers
Citation
Patrick Bosc, Vincent Claveau, Olivier Pivert, Laurent Ughetto. Graded-Inclusion-Based Information Retrieval Systems. ECIR - European Conference on Information Retrieval, Apr 2009, Toulouse, France. pp.252-263, ⟨10.1007/978-3-642-00958-7_24⟩. ⟨hal-00843880⟩
Share
Metrics
Record views
168
