Noisy Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2013
Noisy Optimization
The black box complexity of noisy-optimization is a great research area, with many real-world applications. Various criteria can be used: cumulative regret, simple regret, uniform rates. We discuss the impact of the use of second order information (improved rates under low noise assumption), or local sampling (slower simple regret convergence), or evolutionary optimization with revaluations (as efficient as mathematical programming in some cases with cumulative regret).
noisyOptimizationSurvey.pdf (224.66 Ko) Télécharger le fichier
hal-00844305 , version 1 (14-07-2013)
  • HAL Id : hal-00844305 , version 1
Sandra Astete-Morales, Marie-Liesse Cauwet, Adrien Couetoux, Jérémie Decock, Jialin Liu, et al.. Noisy Optimization. Dagstuhl seminar 13271, 2013, Dagstuhl, Germany. 2013. ⟨hal-00844305⟩
378 Consultations
122 Téléchargements
