Soft variable-structure controls: a survey, Automatica, vol.40, issue.11, pp.1821-1844, 2004. ,
DOI : 10.1016/j.automatica.2004.05.017
A survey of applications of second-order sliding mode control to mechanical systems, International Journal of Control, vol.76, issue.9-10, pp.875-892, 2003. ,
DOI : 10.1080/0020717031000099010
High order sliding mode observer for linear systems with unbounded unknown inputs, International Journal of Control, vol.15, issue.9, pp.1920-1929, 2010. ,
DOI : 10.1109/TAC.1987.1104530
Finite-time output stabilization of the double integrator, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5906-5911, 2012. ,
DOI : 10.1109/CDC.2012.6426565
URL : https://hal.archives-ouvertes.fr/hal-01056207
Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000. ,
DOI : 10.1137/S0363012997321358
Control of nonlinear dynamical systems: methods and applications, 2008. ,
DOI : 10.1007/978-3-540-70784-4
Introduction to calculus and analysis (, 2000. ,
Modern Control Systems, IEEE Transactions on Systems, Man, and Cybernetics, vol.11, issue.8, 2008. ,
DOI : 10.1109/TSMC.1981.4308749
A continuous-time observer which converges in finite time, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1202-1204, 2002. ,
DOI : 10.1109/TAC.2002.800673
On multi-input backstepping design with second order sliding modes for a class of uncertain nonlinear systems, International Journal of Control, vol.71, issue.5, pp.767-788, 1998. ,
DOI : 10.1080/002071798221560
Differential equations with discontinuous right-hand side, 1988. ,
DOI : 10.1090/trans2/042/13
Finite Time Controllers, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.760-770, 1986. ,
DOI : 10.1137/0324047
Finite-time stabilization and stabilizability of a class of controllable systems, Systems & Control Letters, vol.46, issue.4, pp.231-236, 2002. ,
DOI : 10.1016/S0167-6911(02)00119-6
A general approach to synthesis problem, Doklady Academii Nauk SSSR, vol.248, pp.1051-1063, 1979. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005. ,
DOI : 10.1016/j.automatica.2004.11.029
Quasi-continuous high-order sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1812-1816, 2005. ,
DOI : 10.1109/TAC.2005.858646
A Global High-Gain Finite-Time Observer, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1500-1506, 2010. ,
DOI : 10.1109/TAC.2010.2045698
URL : https://hal.archives-ouvertes.fr/hal-00455790
Finite-Time Stability and Stabilization: State of the Art, Lecture Notes in Control and Information Sciences, vol.334, pp.23-41, 2006. ,
DOI : 10.1007/11612735_2
Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
DOI : 10.1137/S0363012903425593
Discontinous systems: Lyapunov analysis and robust synthesis under uncertainty conditions, 2009. ,
Finite-Time Observers: Application to Secure Communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
DOI : 10.1109/TAC.2007.914264
URL : https://hal.archives-ouvertes.fr/inria-00176758
Lyapunov function design for finite-time convergence analysis: ???Twisting??? controller for second-order sliding mode realization, Automatica, vol.45, issue.2, pp.444-448, 2009. ,
DOI : 10.1016/j.automatica.2008.07.013
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966. ,
DOI : 10.1007/BF02844106
Global Finite-Time Observers for Lipschitz Nonlinear Systems, IEEE Transactions on Automatic Control, vol.56, issue.2, pp.418-424, 2011. ,
DOI : 10.1109/TAC.2010.2088610
Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009. ,
DOI : 10.1080/10241230306724
