Multiple model adaptive control with safe switching, International Journal of Adaptive Control and Signal Processing, vol.35, issue.5, p.445470, 2001. ,
DOI : 10.1002/acs.684
The generalized Maxwell-slip model: a novel model for friction Simulation and compensation, IEEE Transactions on Automatic Control, vol.50, issue.11, p.5018831887, 2005. ,
DOI : 10.1109/TAC.2005.858676
Efficient Conversion of Mixed Logical Dynamical Systems Into an Equivalent Piecewise Affine Form, IEEE Transactions on Automatic Control, vol.49, issue.5, pp.832-838, 2004. ,
DOI : 10.1109/TAC.2004.828315
A new model for control of systems with friction, IEEE Transactions on Automatic Control, vol.40, issue.3, p.419425, 1995. ,
DOI : 10.1109/9.376053
Uniting global and local controllers under acting disturbances, Automatica, vol.42, issue.3, pp.489-495, 2006. ,
DOI : 10.1016/j.automatica.2005.11.003
System Identification: Parameter and State Estimation, 1974. ,
Injection engine as a control object. I. Schematic diagram of the engine and synthesis of a mathematical model, Journal of Computer and Systems Sciences International, vol.49, issue.5, pp.5-811, 2010. ,
DOI : 10.1134/S1064230710050151
Equivalence of hybrid dynamical models, Automatica, vol.37, issue.7, pp.1085-1091, 2001. ,
DOI : 10.1016/S0005-1098(01)00059-0
An Anti-Windup Design for Linear Systems with Input Saturation, Automatica, vol.34, issue.5, pp.559-574, 1998. ,
DOI : 10.1016/S0005-1098(97)00194-5
Multiple Model Adaptive Control With Mixing, IEEE Transactions on Automatic Control, vol.55, issue.8, p.18221836 ,
DOI : 10.1109/TAC.2010.2042345
System Identification: Theory for the User, 1987. ,
Switching in Systems and Control, 2003. ,
DOI : 10.1007/978-1-4612-0017-8
Iterative Solution of Nonlinear Equations in Several Variables, Classics in Applied Mathematics, SIAM, 2000. ,
DOI : 10.1137/1.9780898719468
Modeling and Identification of Elastic Robot Joints With Hysteresis and Backlash, IEEE Transactions on Industrial Electronics, vol.56, issue.10, p.5638403847, 2009. ,
DOI : 10.1109/TIE.2009.2015752
Anti-windup Compensation of Input Constrained Systems: Synthesis using Riccati Equations, 2009. ,
Fuzzy identification of systems and its applications to modeling and control, IEEE Transactions on Systems, Man, and Cybernetics, vol.15, issue.1, pp.116-132, 1985. ,
DOI : 10.1109/TSMC.1985.6313399
A simple PD controller for robots with elastic joints Automatic Control, IEEE Transactions on, vol.36, issue.10, pp.1208-1213, 1991. ,
On-Line Identification of Air-to-Fuel Ratio Dynamics in a Sequentially Injected SI Engine, SAE Technical Paper Series, pp.10-4271, 1993. ,
DOI : 10.4271/930857
