FCAST: Object Delivery for the Asynchronous Layered Coding (ALC) and NACK-Oriented Reliable Multicast (NORM) Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2013
This document introduces the FCAST reliable object (e.g., file) delivery application. It is designed to operate either on top of the underlying Asynchronous Layered Coding (ALC) / Layered Coding Transport (LCT) reliable multicast transport protocol or the NACK-Oriented Reliable Multicast (NORM) transport protocol.
rfc6968.pdf (120.57 Ko) Télécharger le fichier
hal-00844825 , version 1 (16-07-2013)
  • HAL Id : hal-00844825 , version 1
Vincent Roca, Brian Adamson. FCAST: Object Delivery for the Asynchronous Layered Coding (ALC) and NACK-Oriented Reliable Multicast (NORM) Protocols. 2013. ⟨hal-00844825⟩
261 Consultations
218 Téléchargements
