Observation of quantum state collapse and revival due to the single-photon Kerr effect - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Année : 2013
To create and manipulate non-classical states of light for quantum information protocols, a strong, nonlinear interaction at the single-photon level is required. One approach to the generation of suitable interactions is to couple photons to atoms, as in the strong coupling regime of cavity quantum electrodynamic systems1, 2. In these systems, however, the quantum state of the light is only indirectly controlled by manipulating the atoms3. A direct photon-photon interaction occurs in so-called Kerr media, which typically induce only weak nonlinearity at the cost of significant loss. So far, it has not been possible to reach the single-photon Kerr regime, in which the interaction strength between individual photons exceeds the loss rate. Here, using a three-dimensional circuit quantum electrodynamic architecture4, we engineer an artificial Kerr medium that enters this regime and allows the observation of new quantum effects. We realize a gedanken experiment5 in which the collapse and revival of a coherent state can be observed. This time evolution is a consequence of the quantization of the light field in the cavity and the nonlinear interaction between individual photons. During the evolution, non-classical superpositions of coherent states (that is, multi-component 'Schrödinger cat' states) are formed. We visualize this evolution by measuring the Husimi Q function and confirm the non-classical properties of these transient states by cavity state tomography. The ability to create and manipulate superpositions of coherent states in such a high-quality-factor photon mode opens perspectives for combining the physics of continuous variables6 with superconducting circuits. The single-photon Kerr effect could be used in quantum non-demolition measurement of photons7, single-photon generation8, autonomous quantum feedback schemes9 and quantum logic operations10.
hal-00845264 , version 1 (16-07-2013)
Gerhard Kirchmair, Brian Vlastakis, Zaki Leghtas, S.E. Nigg, H. Paik, et al.. Observation of quantum state collapse and revival due to the single-photon Kerr effect. Nature, 2013, 495, pp.205--209. ⟨10.1038/nature11902⟩. ⟨hal-00845264⟩
149 Consultations
0 Téléchargements
