Conference papers
Camera Localization Using Mutual Information-Based Multiplane Tracking
Bertrand Delabarre 1 Eric Marchand 1
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This paper deals with dense visual tracking robust towards scene perturbations using 3D information to provide a space-time coherency. The proposed method is based on an piecewise-planar scenes visual tracking algorithm which aims to minimize an error between an observed image and a reference template by estimating the parameters of a rigid 3D transfor- mation taking into acount the relative positions of the planes in the scene. The major drawback of this approch stems from the registration function used to perform the minimization (the sum of squared differences) as it is very poorly robust towards scene variations. In this paper, the tracking process is adapted to take into account two more complex registration functions. First, the sum of conditional variance. Since it is invariant to global illumination variations, the proposed algorithm is robust with relation to those conditions whilst keeping a low computation complexity. Then, the mutual information is considered. In that case the complexity is greater but so is the robustness towards non global illumination variations, specularities or occlusions. The proposed approaches, after being described, are tested on different scenes under varying illumination conditions to assess their respective efficiency.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-00845301
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Tuesday, July 16, 2013 - 5:30:31 PM
Last modification on : Thursday, January 20, 2022 - 5:30:13 PM
Long-term archiving on: : Wednesday, April 5, 2017 - 12:58:17 PM
File
2013_iros_delabarre.pdf
Identifiers
  • HAL Id : hal-00845301, version 1
Citation
Bertrand Delabarre, Eric Marchand. Camera Localization Using Mutual Information-Based Multiplane Tracking. IEEE/RSJ International Conference on Intelligent Robots and Systems, IROS'13, Nov 2013, Tokyo, Japan. pp.1620-1625. ⟨hal-00845301⟩
Share
Metrics
Record views
346
Files downloads
182
