Conference papers
Multiple alignment of biological networks: A flexible approach
Yves-Pol Deniélou 1 Frédéric Boyer 1 Alain Viari 1 Marie-France Sagot 1, *
* Corresponding author
1 BAMBOO - An algorithmic view on genomes, cells, and environments
Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
Abstract : Recent experimental progress is once again producing a huge quantity of data in various areas of biology, in particular on protein interactions. In order to extract meaningful information from this data, researchers typically use a graph representation to which they apply network alignment tools. Because of the combinatorial difficulty of the network alignment problem, most of the algorithms developed so far are heuristics, and the exact ones are of no use in practice on large numbers of networks. In this paper, we propose a unified scheme on the question of network alignment and we present a new algorithm, C3Part-M, based on the work by Boyer et al., that is much more efficient than the original one in the case of multiple networks. We compare it as concerns protein-protein interaction networks to a recently proposed alignment tool, NetworkBLAST-M, and show that we recover similar results, while using a different but exact approach.
Complete list of metadata
https://hal.inria.fr/hal-00845384
Contributor : Marie-France Sagot Connect in order to contact the contributor
Submitted on : Wednesday, July 17, 2013 - 8:31:49 AM
Last modification on : Sunday, September 25, 2022 - 3:56:38 AM
Links full text
Identifiers
Citation
Yves-Pol Deniélou, Frédéric Boyer, Alain Viari, Marie-France Sagot. Multiple alignment of biological networks: A flexible approach. Combinatorial Pattern Matching (CPM), Jun 2009, Lille, France. pp.263-273, ⟨10.1007/978-3-642-02441-2_23⟩. ⟨hal-00845384⟩
Share
Metrics
Record views
112
