Appearance-based segmentation of indoors/outdoors sequences of spherical views - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Navigating in large scale, complex and dynamic environments requires reliable representations able to capture metric, topological and semantic aspects of the scene for sup- porting path planing and real time motion control. In a previous work [11], we addressed metric and topological representations thanks to a multi-cameras system which allows building of dense visual maps of large scale 3D environments. The map is a set of locally accurate spherical panoramas related by 6dof poses graph. The work presented here is a further step toward a semantic representation. We aim at detecting the changes in the structural properties of the scene during navigation. Structural properties are estimated online using a global descriptor relying on spherical harmonics which are particularly well-fitted to capture properties in spherical views. A change-point detection algorithm based on a statistical Neyman-Pearson test allows us to find optimal transitions between topological places. Results are presented and discussed both for indoors and outdoors experiments.
2013_iros_chapoulie.pdf (740.82 Ko) Télécharger le fichier
hal-00845450 , version 1 (17-07-2013)
  • HAL Id : hal-00845450 , version 1
Alexandre Chapoulie, Patrick Rives, David Filliat. Appearance-based segmentation of indoors/outdoors sequences of spherical views. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'2013, Nov 2013, Tokyo, Japan. pp.1946-1951. ⟨hal-00845450⟩
563 Consultations
239 Téléchargements
