Three applications of GPU computing in neuroscience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computing in Science and Engineering Année : 2012
Three scenarios outlined here show the benefits of using a computer system with multiple GPUs in theoretical neuroscience. In each instance, it's clear that the GPU speedup considerably helps answer a scientific or technological question.
Fichier non déposé
hal-00845582 , version 1 (17-07-2013)
Javier Baladron, Diego Fasoli, Olivier Faugeras. Three applications of GPU computing in neuroscience. Computing in Science and Engineering, 2012, 14 (3), pp.40-47. ⟨10.1109/MCSE.2011.119⟩. ⟨hal-00845582⟩
144 Consultations
0 Téléchargements
