Burned area mapping using multi-temporal moderate spatial resolution data???a bi-directional reflectance model-based expectation approach, Remote Sensing of Environment, vol.83, issue.1-2, pp.263-286, 2002. ,
DOI : 10.1016/S0034-4257(02)00077-9
Fire mapping for managers in North Australian savanna; an object orientated classification model for MODIS imagery, Proc. of ARSPC'12, Fremantle , Western Australia, pp.1-12, 2004. ,
An active-fire based burned area mapping algorithm for the MODIS sensor, Remote Sensing of Environment, vol.113, issue.2, pp.408-420, 2009. ,
DOI : 10.1016/j.rse.2008.10.006
Algorithm for solution of a problem of maximum flow in networks with power estimation, Doklady Akademii Nauk SSSR, issue.194, pp.1277-1280, 1970. ,
An experimental comparison of min-cut/max-flow algorithms for energy minimization in vision, pp.1124-1137, 2004. ,
Morphological Image Analysis, 2003. ,
