An analytical method for computing Hopf bifurcation curves in neural field networks with space-dependent delays - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2011
We give an analytical parametrization of the curves of purely imaginary eigenvalues in the delay-parameter plane of the linearized neural field network equations with space-dependent delays. In order to determine if the rightmost eigenvalue is purely imaginary, we have to compute a finite number of such curves; the number of curves is bounded by a constant for which we give an expression. The Hopf bifurcation curve lies on these curves.
hal-00845727 , version 1 (17-07-2013)
Romain Veltz. An analytical method for computing Hopf bifurcation curves in neural field networks with space-dependent delays. Comptes Rendus. Mathématique, 2011, 349 (13-14), pp.749--752. ⟨10.1016/j.crma.2011.06.014⟩. ⟨hal-00845727⟩
217 Consultations
0 Téléchargements
