New interface
Preprints, Working Papers, ...
Mean Field description of and propagation of chaos in recurrent multipopulation networks of Hodgkin-Huxley and Fitzhugh-Nagumo neurons
Javier Baladron 1 Diego Fasoli 1 Olivier Faugeras 1 Jonathan Touboul 1
1 NEUROMATHCOMP
CRISAM - Inria Sophia Antipolis - Méditerranée , INRIA Rocquencourt, ENS-PSL - École normale supérieure - Paris, UNS - Université Nice Sophia Antipolis (1965 - 2019), CNRS - Centre National de la Recherche Scientifique : UMR8548
Abstract : We derive the mean-field equations arising as the limit of a network of interacting spiking neurons, as the number of neurons goes to infinity. The neurons belong to a fixed number of populations and are represented either by the Hodgkin-Huxley model or by one of its simplified version, the Fitzhugh-Nagumo model. The synapses between neurons are either electrical or chemical. The network is assumed to be fully connected. The maximum conductances vary randomly. Under the condition that all neurons initial conditions are drawn independently from the same law that depends only on the population they belong to, we prove that a propagation of chaos phenomenon takes places, namely that in the mean-field limit, any finite number of neurons become independent and, within each population, have the same probability distribution. This probability distribution is solution of a set of implicit equations, either nonlinear stochastic differential equations resembling the McKean-Vlasov equations, or non-local partial differential equations resembling the McKean-Vlasov-Fokker- Planck equations. We prove the well-posedness of these equations, i.e. the existence and uniqueness of a solution. We also show the results of some preliminary numerical experiments that indicate that the mean-field equations are a good representation of the mean activity of a ?finite size network, even for modest sizes. These experiment also indicate that the McKean-Vlasov-Fokker- Planck equations may be a good way to understand the mean-field dynamics through, e.g., a bifurcation analysis.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-00846140
Contributor : Pierre Kornprobst Connect in order to contact the contributor
Submitted on : Thursday, July 18, 2013 - 3:57:47 PM
Last modification on : Thursday, August 4, 2022 - 4:54:04 PM
Links full text
Identifiers
  • HAL Id : hal-00846140, version 1
  • ARXIV : 1110.4294
Collections
Citation
Javier Baladron, Diego Fasoli, Olivier Faugeras, Jonathan Touboul. Mean Field description of and propagation of chaos in recurrent multipopulation networks of Hodgkin-Huxley and Fitzhugh-Nagumo neurons. {date}. ⟨hal-00846140⟩
Share
Metrics
Record views
170
