Software Synthesis from Dataflow Graphs, 1996. ,
DOI : 10.1007/978-1-4613-1389-2
P2012: Building an ecosystem for a scalable, modular and high-efficiency embedded computing accelerator, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.983-987, 2012. ,
DOI : 10.1109/DATE.2012.6176639
Parameterized dataflow modeling for DSP systems, IEEE Transactions on Signal Processing, vol.49, issue.10, pp.2408-2421, 2001. ,
DOI : 10.1109/78.950795
Cycle-static dataflow, IEEE Transactions on Signal Processing, vol.44, issue.2, pp.397-408, 1996. ,
DOI : 10.1109/78.485935
Scheduling dynamic dataflow graphs with bounded memory using the token flow model, IEEE International Conference on Acoustics Speech and Signal Processing, 1993. ,
DOI : 10.1109/ICASSP.1993.319147
Static scheduling and code generation from dynamic dataflow graphs with integer-valued control streams, Proceedings of 1994 28th Asilomar Conference on Signals, Systems and Computers, pp.508-513, 1994. ,
DOI : 10.1109/ACSSC.1994.471505
SPDF: A schedulable parametric data-flow MoC, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.769-774, 2012. ,
DOI : 10.1109/DATE.2012.6176572
URL : https://hal.archives-ouvertes.fr/hal-00744376
Hierarchical finite state machines with multiple concurrency models, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.18, issue.6, pp.742-760, 1999. ,
DOI : 10.1109/43.766725
Dynamic configuration of dataflow graph topology for dsp system design, IEEE ICASSP, 2005. ,
Synchronous data flow, Proceedings of the IEEE, pp.1235-1245, 1987. ,
DOI : 10.1109/PROC.1987.13876
Fractional rate dataflow model and efficient code synthesis for multimedia applications, LCTES-SCOPES, pp.12-17, 2002. ,
Dynamic data flow and control flow in high level DSP code synthesis, Proceedings of ICASSP '94. IEEE International Conference on Acoustics, Speech and Signal Processing, pp.449-452, 1994. ,
DOI : 10.1109/ICASSP.1994.389614
A scenarioaware data flow model for combined long-run average and worst-case performance analysis, MEMOCODE, pp.185-194, 2006. ,
Teleport messaging for distributed stream programs, Proceedings of the tenth ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '05, pp.224-235, 2005. ,
DOI : 10.1145/1065944.1065975
Cyclo-dynamic dataflow, Proceedings of 4th Euromicro Workshop on Parallel and Distributed Processing, pp.319-326, 1996. ,
DOI : 10.1109/EMPDP.1996.500603
Buffer capacity computation for throughput constrained streaming applications with data-dependent inter-task commnication, ACM Trans. Embedded Comput. Syst, vol.10, issue.2, p.17, 2010. ,
