Robust Fault Diagnosis for Systems with Electronic Induced Delays - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (1) , (2) , (3)
1
2
3
A problem of robust fault diagnosis of digital controlled continuous-time systems with uncertain time-varying input delay is studied in this paper. Two residual-based fault detection and isolation (FDI) schemes are proposed that are robust in terms of time-varying delays induced by the electronic devices and disturbances. The idea of both proposed methods is to transform the uncertainty caused by delays into unknown inputs and decouple them by means of eigenstructure assignment (EA) technique. The first method utilizes a Cayley-Hamilton theorem based transformation and the second relies on a first order Pad'e approximation of the time delay. Finally, the applicability and effectiveness of the proposed methods is illustrated through simulation results from the "high-fidelity" industrial simulator, provided by Thales Alenia Space.
ACD2012.pdf (280.38 Ko) Télécharger le fichier
Dates and versions
hal-00847122 , version 1 (22-07-2013)
Identifiers
  • HAL Id : hal-00847122 , version 1
Cite
Robert Fonod, David Henry, Eric Bornschlegl, Catherine Charbonnel. Robust Fault Diagnosis for Systems with Electronic Induced Delays. 10th European Workshop on Advanced Control and Diagnosis, Nov 2012, Copenhagen, Denmark. ⟨hal-00847122⟩
141 View
73 Download
Share
