Journal articles
Control and Stability Analyzing of the Time-Delay Systems with Time-Varying Delays
Abstract : Systems with delays are a specific group of dynamic systems. The fact that some delays can be short and some can be long makes system analysis and control design much more complex. In this paper we present a proposal to solve the problem of stability and control design of continuous time systems with time-varying delays. Based on the Lyapunov-Krasovskii functional the stability condition is derived using the linear matrix inequality (LMI) techniques, and convex optimization principle to find LMI variables which simultaneously satisfies the limitations given by the theory of Lyapunov-Krasovskii functionals. Obtained solution is the feasible convex LMI problem for the static controller design. Finally the design method is demonstrated using a system model example.
Document type :
Journal articles
Complete list of metadata
Cited literature [11 references]  Display  Hide  Download
https://hal.inria.fr/hal-00847151
Contributor : Robert Fonod Connect in order to contact the contributor
Submitted on : Friday, July 26, 2013 - 10:15:26 AM
Last modification on : Friday, July 26, 2013 - 10:43:21 AM
Long-term archiving on: : Sunday, October 27, 2013 - 3:16:57 AM
File
AEI2011.pdf
Identifiers
Citation
Daniel Gontkovic, Robert Fonod. Control and Stability Analyzing of the Time-Delay Systems with Time-Varying Delays. Acta Electrotechnica et Informatica, Versita, 2011, Acta Electrotechnica et Informatica, 11 (3), pp.70-74. ⟨10.2478/v10198-011-0032-9⟩. ⟨hal-00847151⟩
Share
Metrics
Record views
54
Files downloads
954
