Fully Bayesian joint model for MR brain scan tissue and structure segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In most approaches, tissue and subcortical structure segmentations of MR brain scans are handled globally over the entire brain volume through two relatively independent sequential steps. We propose a fully Bayesian joint model that integrates local tissue and structure segmentations and local intensity distributions. It is based on the specification of three conditional Markov Random Field (MRF) models. The first two encode cooperations between tissue and structure segmentations and integrate a priori anatomical knowledge. The third model specifies a Markovian spatial prior over the model parameters that enables local estimations while ensuring their consistency, handling this way nonuniformity of intensity without any bias field modelization. The complete joint model provides a sound theoretical framework for carrying out tissue and structure segmentation by distributing a set of local and cooperative MRF models. The evaluation, using a previously affine-registred atlas of 17 structures and performed on both phantoms and real 3T brain scans, shows good results.
FBM-MICCAI08.pdf (329.13 Ko) Télécharger le fichier
inserm-00356883 , version 1 (28-01-2009)
Benoit Scherrer, Florence Forbes, Catherine Garbay, Michel Dojat. Fully Bayesian joint model for MR brain scan tissue and structure segmentation. 11th International Conference on Medical Image Computing and Computer-Assisted Intervention – MICCAI 2008, Sep 2008, New York, NY, United States. pp.1066-1074, ⟨10.1007/978-3-540-85990-1_128⟩. ⟨inserm-00356883⟩
409 Consultations
246 Téléchargements
