Parallel multigrid smoothing: polynomial versus Gauss???Seidel, Journal of Computational Physics, vol.188, issue.2, pp.593-610, 2003. ,
DOI : 10.1016/S0021-9991(03)00194-3
Multigrid Smoothers for Ultraparallel Computing, SIAM Journal on Scientific Computing, vol.33, issue.5, pp.2864-2887, 2011. ,
DOI : 10.1137/100798806
Aposteriori error estimation for finite element solutions of Helmholtz' equation???Part II: estimation of the pollution error, International Journal for Numerical Methods in Engineering, vol.37, issue.21, pp.3883-3900, 1997. ,
DOI : 10.1002/(SICI)1097-0207(19971115)40:21<3883::AID-NME231>3.0.CO;2-V
On accuracy conditions for the numerical computation of waves, Journal of Computational Physics, vol.59, issue.3, pp.396-404, 1985. ,
DOI : 10.1016/0021-9991(85)90119-6
A perfectly matched layer for the absorption of electromagnetic waves, Journal of Computational Physics, vol.114, issue.2, pp.185-200, 1994. ,
DOI : 10.1006/jcph.1994.1159
A Massively Parallel Multigrid Method for Finite Elements, Computing in Science & Engineering, vol.8, issue.6, pp.56-62, 2006. ,
DOI : 10.1109/MCSE.2006.102
Algebraic Multilevel Preconditioner for the Helmholtz Equation in Heterogeneous Media, SIAM Journal on Scientific Computing, vol.31, issue.5, pp.31-3781, 2009. ,
DOI : 10.1137/080725702
Adaptive Algebraic Multigrid, SIAM Journal on Scientific Computing, vol.27, issue.4, pp.1261-1286, 2006. ,
DOI : 10.1137/040614402
Un solveur linéaire haute performance de systèmes linéaires creux couplant des méthodes multigrilles et directes pour la résolution des équations de Maxwell 3D en régime harmonique, 2011. ,
A Parallel Full Geometric Multigrid Solver for Time Harmonic Maxwell Problems, SIAM Journal on Scientific Computing, vol.36, issue.2, 2013. ,
DOI : 10.1137/130909512
URL : https://hal.archives-ouvertes.fr/hal-00847966
An Aggregation Multilevel Method Using Smooth Error Vectors, SIAM Journal on Scientific Computing, vol.27, issue.5, pp.1727-1741, 2006. ,
DOI : 10.1137/040608192
A survey of parallelization techniques for multigrid solvers, Frontiers of Parallel Processing For Scientific Computing, 2006. ,
A Multigrid Method Enhanced by Krylov Subspace Iteration for Discrete Helmholtz Equations, SIAM Journal on Scientific Computing, vol.23, issue.4, pp.1291-1315, 2001. ,
DOI : 10.1137/S1064827501357190
Advances in Iterative Methods and Preconditioners for the Helmholtz Equation, Archives of Computational Methods in Engineering, vol.15, issue.2, pp.37-66, 2008. ,
DOI : 10.1007/s11831-007-9013-7
A Novel Multigrid Based Preconditioner For Heterogeneous Helmholtz Problems, SIAM Journal on Scientific Computing, vol.27, issue.4, pp.1471-1492, 2006. ,
DOI : 10.1137/040615195
An introduction to algebraic multigrid solver, UCRL-JRNL-220851, 2006. ,
Software for simplified Lanczos and QMR algorithms, Applied Numerical Mathematics, vol.19, issue.3, pp.319-341, 1995. ,
DOI : 10.1016/0168-9274(95)00089-5
Classical multigrid method: Efficient for diffusion problems but ineffective for wave propagation problems, Conf. at Inria Sophia Antipolis, 2009. ,
Analysis of a Multigrid Algorithm for Time Harmonic Maxwell Equations, SIAM Journal on Numerical Analysis, vol.42, issue.1, pp.90-108, 2004. ,
DOI : 10.1137/S003614290139490X
High performance multigrid in current large scale parallel computers, 9th Workshop on Parallel Systems and Algorithms, 2008. ,
A fast method for the solution of the Helmholtz equation, Journal of Computational Physics, vol.230, issue.12, pp.4403-4418, 2011. ,
DOI : 10.1016/j.jcp.2011.01.015
Adaptive finite element techniques for the Maxwell equations using implicit a posteriori error estimates, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.17-18, pp.1620-1638, 2008. ,
DOI : 10.1016/j.cma.2007.12.006
PaStiX: a high-performance parallel direct solver for sparse symmetric positive definite systems, Parallel Computing, vol.28, issue.2, pp.301-321, 2002. ,
DOI : 10.1016/S0167-8191(01)00141-7
Nodal Auxiliary Space Preconditioning in H(curl) and H(div) Spaces, SIAM Journal on Numerical Analysis, vol.45, issue.6, pp.2483-2509, 2007. ,
DOI : 10.1137/060660588
Parallel uniform mesh multiplication applied to Navier-Stokes solver, Computer and Fluids, p.17, 2012. ,
DOI : 10.1016/j.compfluid.2012.04.017
Toward an h-Independent Algebraic Multigrid Method for Maxwell's Equations, SIAM Journal on Scientific Computing, vol.27, issue.5, pp.1669-1688, 2006. ,
DOI : 10.1137/040608118
A Multigrid Method for Variable Coefficient Maxwell's Equations, SIAM Journal on Scientific Computing, vol.27, issue.5, pp.1689-1708, 2006. ,
DOI : 10.1137/040608283
Multigrid Simulation for High-Frequency Solutions of the Helmholtz Problem in Heterogeneous Media, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.684-701, 2002. ,
DOI : 10.1137/S1064827501385426
Parallel Auxiliary Space AMG For H(Curl) Problems, Journal of Computational Mathematics, vol.27, issue.5, pp.604-623, 2009. ,
DOI : 10.4208/jcm.2009.27.5.013
First order system leastsquares for the Helmholtz equation, SIAM Journal on Scientific Computing, vol.21, pp.1228-1251, 2000. ,
Accuracy Properties of the Wave???Ray Multigrid Algorithm for Helmholtz Equations, SIAM Journal on Scientific Computing, vol.28, issue.4, pp.1228-1251, 2006. ,
DOI : 10.1137/040620461
Algebraic Multigrid Solvers for Complex-Valued Matrices, SIAM Journal on Scientific Computing, vol.30, issue.3, pp.1548-1571, 2008. ,
DOI : 10.1137/070687232
A Greedy Strategy for Coarse-Grid Selection, SIAM Journal on Scientific Computing, vol.29, issue.5, pp.1825-1853, 2007. ,
DOI : 10.1137/060654062
Preconditioning of discrete Helmholtz operators perturbed by a diagonal complex matrix, Communications in numerical methods in engineering, pp.801-817, 2000. ,
Coupling of a Multilevel Fast Multipole method and a Microlocal discretization for the 3D Integral Equation of Electromagnetism, C.R. Acad. Sci. Maths, pp.336-505, 2003. ,
A General Interpolation Strategy for Algebraic Multigrid Using Energy Minimization, SIAM Journal on Scientific Computing, vol.33, issue.2, pp.966-991, 2011. ,
DOI : 10.1137/100803031
On the indefinite Helmholtz equation: Complex stretched absorbing boundary layers, iterative analysis, and preconditioning, Journal of Computational Physics, vol.229, issue.22, pp.8384-8405, 2010. ,
DOI : 10.1016/j.jcp.2010.07.022
A parallel multigrid based preconditioner for the 3D heterogeneous highfrequency Helmholtz equation, Journal of Computational Physics, pp.224-431, 2007. ,
GMRES: A Generalized Minimal Residual Algorithm for Solving Nonsymmetric Linear Systems, SIAM Journal on Scientific and Statistical Computing, vol.7, issue.3, pp.856-869, 1986. ,
DOI : 10.1137/0907058
Spectral Analysis of the Discrete Helmholtz Operator Preconditioned with a Shifted Laplacian, SIAM Journal on Scientific Computing, vol.29, issue.5, pp.29-1942, 2007. ,
DOI : 10.1137/060661491
