New interface
Reports (Research report)
Reachability Analysis of Innermost Rewriting
Thomas Genet 1 Yann Salmon 1
1 CELTIQUE - Software certification with semantic analysis
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
Abstract : Approximating the set of terms reachable by rewriting finds more and more applications ranging from termination proofs of term rewriting systems, cryp- tographic protocol verification to static analysis of programs. However, since approximation techniques do not take rewriting strategies into account, they build very coarse approximations when rewriting is constrained by a specific strategy. In this work, we propose to adapt the Tree Automata Completion algorithm to accurately approximate the set of terms reachable by rewriting under the inner- most strategy. We prove that the proposed technique is sound and precise w.r.t. innermost rewriting. The proposed algorithm has been implemented in the Timbuk reachability tool. Experiments shows that it noticeably improves the accuracy of static analysis for functional programs using the call-by-value evaluation strategy. In particular, for some functional programs needing lazy evaluation to terminate, the computed approximations are precise enough to prove the absence of innermost normal forms, i.e. prove non termination of the program with call-by-value.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-00848260
Contributor : Yann Salmon Connect in order to contact the contributor
Submitted on : Monday, February 10, 2014 - 11:28:38 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:10 AM
Long-term archiving on: : Sunday, April 9, 2017 - 10:42:18 AM
File
main.pdf
Identifiers
  • HAL Id : hal-00848260, version 5
Citation
Thomas Genet, Yann Salmon. Reachability Analysis of Innermost Rewriting. [Research Report] 2013. ⟨hal-00848260v5⟩
Share
Metrics
Record views
591
Files downloads
220
