New interface
Conference papers
Variable Density Compressed Sensing In MRI. Theoretical vs Heuristic Sampling Strategies
Nicolas Chauffert 1, * Philippe Ciuciu 1 Pierre Weiss 2
* Corresponding author
1 PARIETAL - Modelling brain structure, function and variability based on high-field MRI data
NEUROSPIN - Service NEUROSPIN, Inria Saclay - Ile de France
2 PRIMO (ITAV)
IMT - Institut de Mathématiques de Toulouse UMR5219, ITAV - Institut des Technologies Avancées en sciences du Vivant
Abstract : The structure of Magnetic Resonance Images (MRI) and especially their compressibility in an appropriate representation basis enables the application of the compressive sensing theory, which guarantees exact image recovery from incomplete measurements. According to recent theoretical conditions on the reconstruction guarantees, the optimal strategy is to downsample the k-space using an independent drawing of the acquisition basis entries. Here, we first bring a novel answer to the synthesis problem, which amounts to deriving the op- timal distribution (according to a given criterion) from which the data should be sampled. Then, given that the sparsity hypothesis is not fulfilled in the k-space center in MRI, we extend this approach by densely sampling this center and drawing the remaining samples from the optimal distribution. We compare this theoretical approach to heuristic strategies, and show that the proposed two-stage process drastically improves reconstruction results on anatomical MRI.
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-00848271
Contributor : Nicolas Chauffert Connect in order to contact the contributor
Submitted on : Thursday, July 25, 2013 - 5:36:01 PM
Last modification on : Wednesday, November 23, 2022 - 11:54:25 AM
Long-term archiving on: : Wednesday, April 5, 2017 - 4:52:15 PM
isbi.pdf
Identifiers
  • HAL Id : hal-00848271, version 1
  • ARXIV : 1307.6836
Citation
Nicolas Chauffert, Philippe Ciuciu, Pierre Weiss. Variable Density Compressed Sensing In MRI. Theoretical vs Heuristic Sampling Strategies. ISBI - 10th International Symposium on Biomedical Imaging, Apr 2013, San Francisco, United States. ⟨hal-00848271⟩
Share
Metrics
Record views
306
Files downloads
212
