Conference papers
Evolutionary insights from semi-discrete plant epidemic models
Magda Castel 1 Frédéric Marie Hamelin 1 Sylvain Poggi 1 Didier Andrivon 1 Ludovic Mailleret 2, 3
3 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : The coexistence of closely related plant parasitic species is ubiquitous in agriculture. However, understanding the ecological determinants of evolutionary divergence in parasites still represents an issue, in both evolutionary biology and agricultural sci- ences. To our knowledge, the only ecological mechanism which has been generically shown to promote phenotypic divergence in plant parasitic species is spatial host heterogeneity. However, spaceis not the only source of ecological heterogeneity. In- terestingly, crop plant parasites face abrupt, periodic changes in host density due to planting and harvesting. In this paper, we investigate whether such heterogeneity in time can promote evolutionary divergence as well. We make use of an epidemic model that combines continuous and discrete dynamics, to capture sharp seasonal events. Performing an evolutionary invasion analysis, we show that evolutionary branching of the parasite phenotype can occur, assuming there is a trade-off be- tween intra- and inter-season transmission abilities. Since there are experimental evidence for such a trade-off, this study provides further ecological bases for the coexistence of closely related plant parasite species. Moreover, this study provides original insights regarding the coexistence of mono- and poly-cyclic sibling plant pathogens.
Complete list of metadata
https://hal.inria.fr/hal-00848403
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Friday, July 26, 2013 - 10:31:08 AM
Last modification on : Tuesday, May 10, 2022 - 3:00:44 PM
Identifiers
  • HAL Id : hal-00848403, version 1
Citation
Magda Castel, Frédéric Marie Hamelin, Sylvain Poggi, Didier Andrivon, Ludovic Mailleret. Evolutionary insights from semi-discrete plant epidemic models. European Conference on Mathematical and Theoretical Biology, 2011, Krakow, Poland. ⟨hal-00848403⟩
Share
Metrics
Record views
175
