Conference papers
Stability results on some zooplankton size-structured models
Jonathan Rault 1 Eric Benoît 2
1 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : Structured models are increasingly used in biological modelling, particularly to describe marine ecosystems, where the behaviour of individuals is strongly depen- dant of their size. To modelize zooplankton community, we first have to describe how an individual of some size feeds, and then how it uses the acquired food to grow and reproduce (according to some dynamic energy budget in order to guarantee mass conservation). Since the model includes cannibalism throughout zooplank- ton population, we obtain a variant of the well-known McKendrick-von Foerster equation with integral terms which appear in growth, mortality and reproduction. Such models are often hard to analyse mathematically. Nevertheless, with some more hypotheses on the cannibalism behavior, we can find equilibria of the model as fixed points of a function in a finite dimensional space. The linearized system around the equilibrium provides us, thanks to the use of linear semigroup theory, some local (un)stability results about these equilibria. Results obtained will be applied to a simple version of the model, which allows us to go further into the mathematical analysis
Complete list of metadata
https://hal.inria.fr/hal-00848442
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Friday, July 26, 2013 - 10:32:38 AM
Last modification on : Thursday, May 12, 2022 - 3:39:57 PM
Identifiers
  • HAL Id : hal-00848442, version 1
Citation
Jonathan Rault, Eric Benoît. Stability results on some zooplankton size-structured models. European Conference on Mathematical and Theoretical Biology, 2011, Krakow, Poland. ⟨hal-00848442⟩
Share
Metrics
Record views
100
