Stabilization of an oscillating n-dimensional structured population model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider a model of a predator with q size-classes feeding on one resource. The resource is also modelled by a logistic function. This model may have sustained oscillations in dimension (q+1) around an unstable equilibrium. A possible control consists in harvesting every class. We show that (under good assumptions) this model can be reduced to a two-dimensional predator-prey model having sustained oscillations. We design positive controls to suppress the oscillations and to stabilize the equilibrium of the reduced and full model.
Fichier non déposé
hal-00848444 , version 1 (26-07-2013)
Jonathan Rault, Jean-Luc Gouzé. Stabilization of an oscillating n-dimensional structured population model. 20th Mediterranean Conference on Control & Automation (MED), 2012, Barcelona, Spain. pp.372-377, ⟨10.1109/MED.2012.6265666⟩. ⟨hal-00848444⟩
262 Consultations
0 Téléchargements
