Finite element simulations of multiple scattering in acoustic waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Waves in Random and Complex Media Année : 2010
We develop a numerical method to characterize multiple-scattering effects in a duct. To reduce time computations, a FEM method coupled to an integral representation of the scattered pressure field, requiring the evaluation of the duct Green's function, is used, combined with the consideration of random scatterer configurations in the form of perturbed periodic arrays. This strategy reduces the mesh size and allows parallel computations. Application to the computation by an averaging process of effective transmissions is presented. When sending a plane wave, although waveguides involve mode conversion, the mean field is found to be a plane wave. Good agreement is found when comparing to analytical models, not initially designed for a duct, except for some frequencies, recognized to be the band gap frequencies of the underlying periodic arrays. © 2010 Taylor & Francis.
Fichier non déposé
hal-00849578 , version 1 (30-08-2013)
Éric Lunéville, Jean-François Mercier. Finite element simulations of multiple scattering in acoustic waveguides. Waves in Random and Complex Media, 2010, 20 (4), pp.615-633. ⟨10.1080/17455031003753000⟩. ⟨hal-00849578⟩
111 Consultations
0 Téléchargements
