Single-Trial Analysis of Bioelectromagnetic Signals: The Quest for Hidden Information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
This chapter deals with the analysis of multitrial electrophysiology datasets coming from neuroelectromagnetic recordings by electro-encephalography and magneto-encephalography (EEG and MEG). For such measurements, multitrial recordings are necessary in order to extract meaningful information. The obtained datasets present several characteristics: no ground-truth data, high level of noise (defined as the part of the data which is uncorrelated across trials), inter-trial variability. This chapter presents tools that deal with such datasets and their properties. The focus is on two families of data processing methods: data-driven methods, in a section on non-linear dimensionality reduction, and model-driven methods, in a section on Matching Pursuit and its extensions. The importance of correctly capturing the inter-trial variability is underlined in the last section which presents four case-studies in clinical and cognitive neuroscience.
Fichier non déposé
hal-00849690 , version 1 (31-07-2013)
Maureen Clerc, Théodore Papadopoulo, Christian G. Bénar. Single-Trial Analysis of Bioelectromagnetic Signals: The Quest for Hidden Information. Cazals, Frederic and Kornprobst, Pierre. Modeling in Computational Biology and Biomedicine: A Multidisciplinary Endeavor, Springer, pp.237--259, 2013, 978-3-642-31208-3. ⟨10.1007/978-3-642-31208-3⟩. ⟨hal-00849690⟩
159 Consultations
0 Téléchargements
