Computing the Volume of Union of Balls: a Certified Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Mathematical Software Année : 2011
Frédéric Cazals
Kanhere Harshad
  • Fonction : Auteur
  • PersonId : 862493
Balls and spheres are amongst the simplest 3D modeling primitives, and computing the volume of a union of balls is elementary problem. Although a number of strategies addressing this problem have been investigated in several communities, we are not aware of any robust algorithm, and present the first such algorithm. Our calculation relies on the decomposition of the volume of the union into convex regions, namely the restrictions of the balls to their regions in the power diagram. Theoretically, we establish a formula for the volume of a restriction, based on Gauss' divergence theorem. The proof being constructive, we develop the associated algorithm. On the implementation side, we carefully analyse the predicates and constructions involved in the volume calculation, and present a certified implementation relying on interval arithmetic. The result is certified in the sense that the exact volume belongs to the interval computed. Experimental results are presented on hand-crafted models illustrating various difficulties, as well as on the 58,898 models found in the tenth of July 2009 release of the Protein Data Bank.
Fichier non déposé
hal-00849809 , version 1 (01-08-2013)
Frédéric Cazals, Kanhere Harshad, Sébastien Loriot. Computing the Volume of Union of Balls: a Certified Algorithm. ACM Transactions on Mathematical Software, 2011, 38 (1), ⟨10.1145/2049662.2049665⟩. ⟨hal-00849809⟩
Collections
INRIA INRIA2
76 Consultations
0 Téléchargements
