On countably skewed Brownian motion with accumulation point. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Youssef Ouknine
  • Fonction : Auteur
  • PersonId : 944184
Gerald Trutnau
  • Fonction : Auteur
  • PersonId : 944185
In this work we connect the theory of Dirichlet forms and direct stochastic calculus to obtain strong existence and pathwise uniqueness for Brownian motion that is perturbed by a series of constant multiples of local times at a sequence of points that has exactly one accumulation point in $\mathbb{R}$. The considered process is identified as special distorted Brownian motion $X$ in dimension one and is studied thoroughly. Besides strong uniqueness, we present necessary and sufficient conditions for non-explosion, recurrence and positive recurrence as well as for $X$ to be semimartingale and possible applications to advection-diffusion in layered media.
ORTMultiskewAugust2013Sent.pdf (292.43 Ko) Télécharger le fichier
hal-00850095 , version 1 (02-08-2013)
  • HAL Id : hal-00850095 , version 1
Youssef Ouknine, Francesco Russo, Gerald Trutnau. On countably skewed Brownian motion with accumulation point.. 2013. ⟨hal-00850095⟩
261 Consultations
201 Téléchargements
