OpenAlea 2.0: Architecture of an integrated modeling environment on the web
Plant modeling is based on the use of a diverse set of design paradigms (L-systems, visual programming, imperative languages or sketch-based interfaces). In this poster, the architecture of a new multi-paradigm and integrated modeling environment is presented. This desktop application will become a distributed web application, allowing to run simulations on a cloud computing system and share virtual experiments on the web. The modeling environment will run on a web browser using HTML5 and WebGL technologies.
PradalCosteBoudonFournierGodin2013.pdf (46.38 Ko)
Télécharger le fichier
Format : Figure, Image
