OpenAlea 2.0: Architecture of an integrated modeling environment on the web - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Plant modeling is based on the use of a diverse set of design paradigms (L-systems, visual programming, imperative languages or sketch-based interfaces). In this poster, the architecture of a new multi-paradigm and integrated modeling environment is presented. This desktop application will become a distributed web application, allowing to run simulations on a cloud computing system and share virtual experiments on the web. The modeling environment will run on a web browser using HTML5 and WebGL technologies.
PradalCosteBoudonFournierGodin2013.pdf (46.38 Ko) Télécharger le fichier
Format : Figure, Image
hal-00850931 , version 1 (09-08-2013)
  • HAL Id : hal-00850931 , version 1
Christophe Pradal, Julien Coste, Frédéric Boudon, Christian Fournier, Christophe Godin. OpenAlea 2.0: Architecture of an integrated modeling environment on the web. 7th International Conference on Functional-Structural Plant Models, Jun 2013, Saariselkä, Finland. pp.213. ⟨hal-00850931⟩
542 Consultations
1187 Téléchargements
