A mass-structured individual-based model of the chemostat: convergence and simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
We propose a model of chemostat where the bacterial population is individually-based, each bacterium is explicitly represented and has a mass evolving continuously over time. The substrate concentration is represented as a conventional ordinary differential equation. These two components are coupled with the bacterial consumption. Mechanisms acting on the bacteria are explicitly described (growth, division and up-take). Bacteria interact via consumption. We set the exact Monte Carlo simulation algorithm of this model and its mathematical representation as a stochastic process. We prove the convergence of this process to the solution of an integro-differential equation when the population size tends to infinity. Finally, we propose several numerical simulations.
chemostat_ibm.pdf (6.49 Mo) Télécharger le fichier
hal-00850959 , version 1 (09-08-2013)
hal-00850959 , version 2 (10-08-2013)
hal-00850959 , version 3 (07-11-2013)
Fabien Campillo, Coralie Fritsch. A mass-structured individual-based model of the chemostat: convergence and simulation. 2013. ⟨hal-00850959v2⟩
494 Consultations
255 Téléchargements
