Abstract : It is well-known that solutions to the Hamilton-Jacobi equation $$\u_t(t,x)+H\big(x,\u_x(t,x)\big)=0$$ fail to be everywhere differentiable. Nevertheless, suppose a solution $u$ turns out to be differentiable at a given point $(t,x)$ in the interior of its domain. May then one deduce that $u$ must be continuously differentiable in a neighborhood of $(t,x)$? Although this question has a negative answer in general, our main result shows that it is indeed the case when the proximal subdifferential of $u(t,\cdot)$ at $x$ is nonempty. Our approach uses the representation of $u$ as the value function of a Bolza problem in the calculus of variations, as well as necessary optimality conditions for such a problem.
