New interface
Conference papers
Efficient decoupled pose estimation from a set of points
Omar Tahri 1 Helder Araujo 1 Youcef Mezouar 2 François Chaumette 3
3 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This paper deals with pose estimation using an iterative scheme. We show that using adequate visual infor- mation, pose estimation can be performed in a decoupling the estimation of translation and rotation. More precisely, we show that pose estimation can be achieved iteratively as a function of only three independent unknowns, which are the translation parameters. An invariant to rotational motion is used to estimate the camera position. Once the camera position is estimated, we show that the rotation can be estimated efficiently using a direct method. The proposed approach is compared against two classical methods from the literature. The results show that using our method, pose tracking in image sequences and the convergence rate for randomly generated poses are improved.
Document type :
Conference papers
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-00851997
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Monday, August 19, 2013 - 3:08:24 PM
Last modification on : Wednesday, March 9, 2022 - 4:38:04 PM
Long-term archiving on: : Wednesday, November 20, 2013 - 4:15:13 AM
File
2013_iros_tahri.pdf
Identifiers
  • HAL Id : hal-00851997, version 1
Citation
Omar Tahri, Helder Araujo, Youcef Mezouar, François Chaumette. Efficient decoupled pose estimation from a set of points. IEEE/RSJ Int. Conf. on Intelligent Robots and Systems, IROS'2013, Nov 2013, Tokyo, Japan. pp.1608-1613. ⟨hal-00851997⟩
Share
Metrics
Record views
363
Files downloads
233
