CO 2 mitigation with microalgae systems. Energy Conversion and Management, pp.475-479, 1997. ,
Hurdles and challenges for modelling and control of microalgae for CO2 mitigation and biofuel production, Journal of Process Control, vol.21, issue.10, pp.1378-1389, 2011. ,
DOI : 10.1016/j.jprocont.2011.07.012
URL : https://hal.archives-ouvertes.fr/hal-00848385
Transient behavior of biological loop models with application to the Droop model, Mathematical Biosciences, vol.127, issue.1, pp.19-43, 1995. ,
DOI : 10.1016/0025-5564(94)00040-7
Non-linear qualitative signal processing for biological systems: application to the algal growth in bioreactors, Mathematical Biosciences, vol.157, issue.1-2, pp.357-372, 1999. ,
DOI : 10.1016/S0025-5564(98)10091-3
Microalgal Reactors: A Review of Enclosed System Designs and Performances, Biotechnology Progress, vol.22, issue.152, pp.1490-1506, 2006. ,
DOI : 10.1002/bp060065r
Bilinear system as a modelling framework for analysis of microalgal growth, Kybernetika, vol.43, issue.1, pp.1-20, 2007. ,
Biodiesel from microalgae, Biotechnology Advances, vol.25, issue.3, pp.294-306, 2007. ,
DOI : 10.1016/j.biotechadv.2007.02.001
Vitamin B12 and Marine Ecology. IV. The Kinetics of Uptake, Growth and Inhibition in Monochrysis Lutheri, Journal of the Marine Biological Association of the United Kingdom, vol.33, issue.03, pp.689-733, 1968. ,
DOI : 10.1038/191868a0
25 Years of Algal Growth Kinetics A Personal View, Botanica Marina, vol.26, issue.3, pp.99-112, 1983. ,
DOI : 10.1515/botm.1983.26.3.99
A model for the relationship between light intensity and the rate of photosynthesis in phytoplankton, Ecological Modelling, vol.42, issue.3-4, pp.199-215, 1988. ,
DOI : 10.1016/0304-3800(88)90057-9
Dynamic behaviour of a model for photosynthesis and photoinhibition, Ecological Modelling, vol.69, issue.1-2, pp.113-133, 1993. ,
DOI : 10.1016/0304-3800(93)90052-T
Photosynthesis???Irradiance Response at Physiological Level: a Mechanistic Model, Journal of Theoretical Biology, vol.213, issue.2, pp.121-127, 2001. ,
DOI : 10.1006/jtbi.2001.2413
A Mechanistic Model of Algal Photoinhibition Induced by Photodamage to Photosystem-II, Journal of Theoretical Biology, vol.214, issue.4, pp.519-546, 2002. ,
DOI : 10.1006/jtbi.2001.2468
CO 2 Mitigation et Renewable Oil from Photosynthetic Microbes: A New Appraisal. Mitigation and Adaptation Strategies for Global Change, pp.573-608, 2007. ,
The attractiveness of the droop equations, Mathematical Biosciences, vol.111, issue.2, pp.261-278, 1992. ,
DOI : 10.1016/0025-5564(92)90074-7
Analyzing and modeling of photobioreactors by combining first principles of physiology and hydrodynamics, Biotechnology and Bioengineering, vol.193, issue.4, pp.382-393, 2004. ,
DOI : 10.1002/bit.10831
Modelling neutral lipid production by the microalga Isochrysis aff. galbana under nitrogen limitation, Bioresource Technology, vol.102, issue.1, pp.142-149, 2011. ,
DOI : 10.1016/j.biortech.2010.06.138
Biodiversity and application of microalgae, Journal of Industrial Microbiology & Biotechnology, vol.87, issue.5-6, pp.477-489, 1996. ,
DOI : 10.1007/BF01574779
LA TECHNIQUE DE CULTURE CONTINUE TH??ORIE ET APPLICATIONS, pp.390-410, 1950. ,
DOI : 10.1016/B978-0-12-460482-7.50023-3
Commercial development of microalgal biotechnology: from the test tube to the marketplace, Biomolecular Engineering, vol.20, issue.4-6, pp.459-466, 2003. ,
DOI : 10.1016/S1389-0344(03)00076-5
Simulations of light intensity variation in photobioreactors, Journal of Biotechnology, vol.131, issue.3, pp.276-285, 2007. ,
DOI : 10.1016/j.jbiotec.2007.05.024
Photobioreactors: production systems for phototrophic microorganisms, Applied Microbiology et Biotechnology, vol.57, pp.287-293, 2001. ,
Model for Photosynthesis and Photoinhibition: Parameter Identification Based on the Harmonic Irradiation <formula formulatype="inline"> <tex>$O_{2}$</tex></formula> Response Measurement, IEEE Transactions on Automatic Control, vol.53, issue.Special Issue, pp.101-108, 2008. ,
DOI : 10.1109/TAC.2007.911345
Averaging for ordinary differential equation and functional differential equations. In I van den Berg and V Neves, editors, The Strength of Nonstandard Analysis, pp.286-305, 2007. ,
The steady states of continuous cultures with low rates of medium renewal per cell, Journal of Experimental Marine Biology and Ecology, vol.178, issue.1, pp.1-15, 1994. ,
DOI : 10.1016/0022-0981(94)90221-6
Anaerobic digestion of microalgae as a necessary step to make microalgal biodiesel sustainable, Biotechnology Advances, vol.27, issue.4, pp.409-416, 2009. ,
DOI : 10.1016/j.biotechadv.2009.03.001
URL : https://hal.archives-ouvertes.fr/hal-00854465
Light reaction in photosynthesis, Can. J. Fish Aquat. Sci, vol.210, pp.1-43, 1981. ,
Experiment selection for the discrimination of semi-quantitative models of dynamical systems, Artificial Intelligence, vol.170, issue.4-5, pp.472-506, 2006. ,
DOI : 10.1016/j.artint.2005.11.001
URL : https://hal.archives-ouvertes.fr/inria-00071639
Photosynthetic efficiency of Chlamydomonas reinhardtii in flashing light, Biotechnology and Bioengineering, vol.12, issue.7, pp.2905-2913, 2011. ,
DOI : 10.1002/bit.23270
An Outlook on Microalgal Biofuels, Science, vol.329, issue.5993, pp.796-799, 2010. ,
DOI : 10.1126/science.1189003
A model integrating fluid dynamics in photosynthesis and photoinhibition processes, Chemical Engineering Science, vol.56, issue.11, pp.3527-3538, 2001. ,
DOI : 10.1016/S0009-2509(01)00048-3
